Project GTO
Click on Images for Full Size
Started "Project GTO" this past Saturday (July 8th, 2006), as many of the AustinModders already know, and wanted to log our progress for all to see here. Hopefully it can give you ideas on your own car project or at least get you stimulated to do something creative.
I recently purchased this Pontiac GTO to replace my daily driver 1997 Mustang. I initially wanted a new 2007 Shelby Mustang, but after waiting so long and comparing the Shelby to the GTO performance/price wise, the GTO just made more sense. That and I could get the GTO now. Hmmmm, instant gratification and a lot of speed and power, or wait another year and pay 20K more. Let me think.... A new Mustang will probably be in my future, but for now the GTO is a fantastic ride and saves me money regardless of the mpg. "It is so choice. If you have the means, I highly recommend picking one up."
[hr]
Part List:
Apple 1.6Ghz Mac Mini Core Duo - A Solo will do but I wanted as much power in the small package as I could get, and I liked the integrated DVDRW - Apple.com - ~$800
Carnetix P1900 V2.0 - DC/DC power supply regulator - works flawlessly with the Mac Mini - Carnetix.com ~$100
Carnetix "MacPac" Cable - Adapts the P1900 so you dont have to cut your Apple supplied power supply for use in car - Carnetix.com ~$25
Lilliput 7" In-Dash Touchscreen (GL701NP/C/T) - Builtin TV Tunner/VGA & Audio IN/Dual RCA Video&Audio IN/Rear Camera IN - Lilliput.tv ~$450
Seidio RBT-2010 Bluetooth GPS receiver - Allows GPS connection via bluetooth - SeidioOnline.com ~$115
Seidio G4200M PPC6700 Phone Cradle - Mounts my phone and adapts the connections for true stereo phone connection and microphone - SeidioOnline.com ~$120
Bytecc 2.5"/3.5" Hard Drive ATA/USB adapter - Allows for add on hard drive for more storage and large file transfers - ByteccUSA.com ~$20
Seagate 200GB 7200RPM - Transfer files/additional storage - Seagate.com ~$70
Streetdeck.com Streetdeck - Windows based "front end" software - Streetdeck.com ~$200 (paid $150 early prepay option prior to initial release)
~10ft of 12-14gauge wire - various wire runs if needed - Hardware/Electronics store ~$5-10
Fabricated pieces:
Front face plate - Laser cut P99 Black acrylic matte finish (You can use your model DIN adapter as well of course)
Acrylic hard drive mounting rails - Clear acrylic
Mac Mini mount/shims
VGA to DVI slim mount cable
Tools Needed:
Preferrably an extra set of hands or 12 ()
Soldering Iron (including various consumables like solder, wick, etc.)
Screwdriver set (various lengths for tight spaces)
Wire Cutters
Wire Strippers
Electrical tape or Wire shrink
Heat gun
Utility knife
Wiring diagrams (clearly labeled) for both wire harnesses in use and your model of car
Volt Meter or Digital Multimeter
Analog or Digital Calipers (taking measurements)
VGA extension cable (will be cut in most cases)
DVI-VGA adapter (will be cut as well in most cases)
USB Keyboard (dont forget this)
USB Mouse (dont forget this)
Driver CDs
USB Flash Memory key (not necessary but makes it easier)
Wire nuts (or various clamp/loop/grip connectors desired - testing)
LinkBack URL
About LinkBacks
