Results 1 to 10 of 20
Thread: 95 Ram...12" touchscreen indash
    Newbie RamPC's Avatar
    Jun 2006
    Edmonton
    95 Ram...12" Indash Touchscreen!
    Hello all,
    This is my first attempt at a carputer install. Hopefully it will end up as good as I hpoe it will.
    So I guess I'll take you through what i've done so far.
    Ok here is what I have to work with...This is where the 12 incher is going.
    I found a dash bezel at the junkers for 5 bucks and it was better than mine so I cut up the original one (the original one was all messed up by the guy who helped himself to my old stereo)
    Then I made this for the screen to go into.
    Jun 2006
    Edmonton
    Jun 2006
    Edmonton
    There is still ALOT more work to do with the screen mount but that is all I have done for now.
    On to the computer.
    So I needed a case...something stong, cheap ,and look like it belongs in the cab of my truck. Heres what I used.
    An hour or two of dremel work and i got all the partitions removed and cut the hole for the I/O Sheild
    The I/O sheild fit good but some hot gule and it wasn't going anywhere.
    Jun 2006
    Edmonton
    I also cut a hole for the psu fan and wifi plug.
    Here are some of the other parts of the system
    Keyboard.
    Gps
    and I have a magnetic wifi anttena that goes on the roof.
    ok Back to the computer. Here is the case with the motherboard psu and hard drive in it.
    Jun 2006
    Edmonton
    I cut a little hole by the handle and added a switch to turn it on
    I also put a LED there because when you turn a computer on a light should go on, that is just the way it is.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Very cool idea with the DeWalt case.
    Tidder
    Try RevFE
    Jun 2006
    Edmonton
    So now that I had it all together I had to test it out.
    Here is my lab/shop/christmas tree storage.
    While testing in the clean room something bizzare happend and my hard drive caught on fire. Good thing it was an old 40 giger
    So I replaced it. First I replaced it with a 10 gig 2.5 inch hdd
    But I didn't like that so I put in a counterfit seagate drive I got stuck with off of Ebay. Oh well it's 200 gigs and it works.
    Jun 2006
    Edmonton
    well here it is up and running. I put it in my truck and drove around abit it worked great. I just had the screen in my lap for now but I wanted to see if the gps was working...it was....and it was cool.
    Well thats all for now I will keep you guys up to date.
    Constant Bitrate damarble's Avatar
    Jan 2006
    Spokane
    I'm liking it so far! Especially the case, since I too used a tool case. Mine was from a Panasonic drill, which just happened to be the same size as my mobo, with less than 1/4" clearance on all sides.
    {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
    MY INSTALLATION LOG
    Jun 2006
    Edmonton
    Thanks guys. I actually put a lot of thought into the case and the drill case was perfect. It's big enough , It's strong , It's portable, and I have a few of them with no drills to put in them.
  1. 2004 Dodge Ram Computer - Touchscreen -Stereo Install
    By DodgeMan in forum Show off your project
    Last Post: 01-08-2009, 07:42 PM
  2. Another crazy mod: RAM booting XP (no, not EWF)
    By SFiorito in forum WinNT Based
    Last Post: 01-18-2007, 08:39 PM
  3. My new 7" motorized Touchscreen..
    By rscultho in forum The Review Palace
    Last Post: 03-08-2006, 07:57 PM
  4. FS lots of ram
    By kderedwolf in forum Classified Archive
    Last Post: 04-29-2005, 07:28 PM
  5. Replies: 15
    Last Post: 04-29-2004, 12:05 AM
