Results 1 to 7 of 7
Thread: Subaru Impreza Wagon Carputer mk II
    Aug 2004
    brooklyn, ny
    I previously had cut open my dash, stashed the via board and all the other peripherals in there, and mounted my screen on top:
    This setup served me well for the past 3 or so years, however I recently moved to a slightly more urban enviroment and decided i want a stealthier install. In wanted to move the screen up where the cubby was (with gps in it, 2nd picture above) and make a custom faceplate where the gps and other peripherals could be intergrated. This is my work so far, if you want to read in more detail visit my flickr set for the project.
    Hopefully in the next 2-3 weeks i'll complete it, and hopefully document the rest of the process.
    Variable Bitrate f1vlad's Avatar
    Feb 2006
    Nashua,NH
    Welcome to another Subaru!
    f1vlad.com/subaru/sparow
    ■■■■■■■■■■■■■■■■■■■■■ 80% progress (sold)
    Aug 2006
    As a new member an the owner of a MY2000 Subaru Wagon I'll be glued to this thread for a while! Quick question, what size of screen (model?) did you manage to fit inside the upper dash compartment?
    Thanks and good luck with the project!
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    i dont wanna rag on you, 'cause that install is lookin pretty good
    but by stealth install, did you mean "stealth-but-the-gps-is-still-visible" install?
    :P
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    wow... that my friends, is an amazing install
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    Aug 2004
    brooklyn, ny
    Its a lilliput 7 inch, hacked into bits
    I've just started with learning to do some molding to make it actually look a (bit) more stock . . . I added a usb hub on the center console, needs some more sanding but works for now:
    the electrical tape around the screen will be removed, and hopefully i can throw together some sides for it which still fit in the cubby
    dirtiest screen evar
    the whole system so far
    another showing the usb hub
    Thanks all for the comments!
    Aug 2004
    brooklyn, ny
    i guess by stealth i meant more "make it look like it would be a ***** to steal" . . . a dash mounted small screen gps isn't as much of a breakin attractor as a 7inch screen, and i like the idea of it being accessible even if the computers off . . . i am going to make it molded into the dash today and spray paint that whole panel, should have some more pics up soon
  1. 98 Nissan Altima OBD II? to carputer???
    By tsparks in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-30-2006, 09:09 AM
  2. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 05:34 PM
  3. Subaru STi Carputer IN
    By hotonSTI in forum Show off your project
    Last Post: 06-14-2004, 03:27 PM
  4. Finally my carputer in 97 Subaru Outback Sport
    By ryuandwings in forum Show off your project
    Last Post: 05-17-2004, 08:25 AM
  5. Gauging Interest - Subaru Impreza Display Housing
    By DustinR in forum Classified Archive
    Last Post: 05-12-2004, 03:28 AM
