Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Another 2005 Mustang
    Newbie Sonic V8's Avatar
    Aug 2006
    I'm about a quarter of way through my install and thought I would share some pics.. I'll give out details of my PC when I am finished as I am still gathering components as I go.. Here are the pics:
    Thanks to Joe for the great idea he provided us on his install. You can see Joe's install here
    FLAC sama's Avatar
    Feb 2006
    London, UK
    looking good. any way you could squeeze a dvd rom in there?
    Aug 2006
    Quote Originally Posted by sama View Post
    As of yet, no.. Until I tear the car apart, I won't know how much room I have to play with. I'm def. looking into a slim line DVD ROM..
    Feb 2006
    Looking great! There is ton of room behind that dash. I started to put the PC behind the dash but then saw how long the cable was that came with my LCD screen (13 feet) and decided to move the CPU to the trunk. I know the dash is pretty easy to take apart, compared to previous cars I've own, but 13 feet of cable? I didn't want to cut or make a custom cable. Turns out that the connector lands directly under the shifter boot so if I need to disable the system then I can just pull the boot and disconnect the monitor cable. Anyways, good luck with your install, keep us informed.
    Mike
    Jul 2006
    How hard was it to recolate the screen and whatnot. Did you have to que new wires and stuff??
    Thanks,
    FR
    Feb 2006
    I managed to just mod the LCD case a little, move the LCD buttons to the back of the case (hot glue) then hot glue the LCD case to the Metra double-din kit. Then run the video and power cables to the trunk for the PC. I have the factory radio's key power (+) running to the back as a signal wire. That way, the amp, PC, and LCD all stay on until the door is opened just like the factory setup. The signal wire acts as the amps remote turn on, the PC's remote turn on, and acutally powers the LCD directly. So I think a total of 4 wires were run and some RCA cables for the factory amp (shaker system) and that's it. I ran everything under the console, under the capet between the console and the rer seat and then under the rear seat to the trunk. I've got a ton of slack right now but I will soon either cut out the slack or move the PC to the far back passenger side corner (the video cable even reaches there with slack)! Let me know if you need any more help or explination.
    Mike
    Aug 2006
    Valencia, CA
    Which LCD screen are you using with that kit?
    Feb 2006
    It was this one:
    http://dynamixcomputers.com/7_dynamix_ultra_bright.html
    Here's a couple of pics of the modififactions I did. I wound up just cutting the button section off of the front hald of the case. Moving the buttons to the back of the case. I can still actually use the remote if I hold it down just below the dash near the back of the console. I've been thinking of moving the IR receiver to the front but just havn't had any reason to remove the LCD since it was installed.
    The inside of the monitor was very nice and clean, and everything seemed seperated into modules, USB, LCD, VGA controller. Nice layout and easy to mode.
    Mike
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Looks awesome Sonic! Looks like you went with the super touchscreen also from your pics. Im glad my build has inspired your's and I appricate the props in the beginning of your thread. This is really cool watching your build as its very similar, but I already see things you did a little bit different that are better. For instance the use of 2 dowels instead of 3 for mounting the TS controller board. What MoBo are you going to run?? Im really looking foward to seeing this built up. Any questions or problems hit me up. Hope your enjoying the mustang! It only gets better with the PC
    -JOE
    Feb 2006
    Listen to blk02si, his install was my inspiration. I've already told my wife it was all his fault!!!
    Mike
  1. Ford Mustang GT 2005 Project Progress
    By enitalp in forum Show off your project
    Last Post: 09-07-2007, 10:33 PM
  2. Another 2005 Mustang install
    By 2 STanGeR in forum Worklogs
    Last Post: 12-02-2005, 11:46 PM
  3. 2005 Mustang GT - First attempt...
    By 05mineralgrey in forum Worklogs
    Last Post: 10-31-2005, 03:29 AM
  4. Where to DL old version of RR?
    By accentsound in forum Road Runner
    Last Post: 07-12-2005, 01:51 AM
  5. 2005 Mustang Gt
    By optrice in forum Newbie
    Last Post: 12-04-2004, 09:10 AM
