Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: 2006 tayota tacoma started.
  1. #11
    _
    Mar 2004
    Little Elm, Texas
    I'm moving this to the work logs section.
    Jan Bennett
  2. #12
    Jul 2005
    Here is the link for the RTA software I use level 4
    http://www.trueaudio.com/rta_abt1.htm
    You will also have to have a mic. This is the most reasonable and works great.
    http://www.behringer.com/ECM8000/index.cfm?lang=ENG
    You will also have to have a mic amp to run the mic on your PC. I wil have to find mine and get the exact model number but I think the this one will work.
    http://www.sweetwater.com/store/detail/Phantom3/
  3. #13
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    that's amazing... by far the most reasonably priced RTA setup I've seen. Thanks for those links!
  4. #14
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by 8675309 View Post
    great post!
    Jan Bennett
  5. #15
    _
    Mar 2004
    Little Elm, Texas
    btw - you might find this thread interesting:
    1/3 Octave Software EQ
    Jan Bennett
  6. #16
    Jul 2005
    http://ozone-for-winamp-3.izotope-inc.qarchive.org/
    here is a plugin that I use on my personal pc and it seems to work really nice. But I am an oldschool fan of tube
    But it will never sound as nice as a true tube amp
  7. #17
    Jul 2005
    Well I ordered the dayton audio 6 inch drivers. This is what I am looking at for enclosure options.
    If I did use a crossover this is the design I would use. It is for a dayton driver and peerless tweeter.by the mid The tweeter will placed in the lower door
    I will be using this design for the tweeter only. Scratch the mid section of this and look at the 12000hz and above tweeter. I will mount it in the upper door. This will raise the sound stage.
    This is what I am looking at for the single 10
  8. #18
    Jul 2005
    sorry I tried 3 dif ways to make these larger
  9. #19
    Jul 2005
    Been out working on the road so I have not had time to do many more updates.
    I do know that I will be using a an amp besides Jbl or the kicker listed. This is one area I will have to scratch the budget idea. I am looking at JL, the higher end kicker, Helix, and Audison.
    I will have to see as time goes.
  10. #20
    Jul 2005
    I have purchased these for the system. Hope I will have more soon.
    4 of these. One in each door
    http://www.partsexpress.com/pe/showd...number=295-372
    4 of these. I have decided to use an aperiodic vent on the dayton mids.
    http://www.partsexpress.com/pe/pshow...TOKEN=78818351
    2 of these. They will be located in the front door lower by the mid
    http://www.partsexpress.com/pe/showd...number=264-834
    2 of these. They will be located in the upper front door playing 12000 hz and above to raise the sound stage.
    http://www.partsexpress.com/pe/showd...number=275-030
  1. My 2006 Civic Install
    By BrentMcGhee in forum Fabrication
    Last Post: 01-31-2008, 12:15 PM
  2. Replies: 2
    Last Post: 05-17-2006, 02:20 AM
  3. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 09:49 PM
  4. Warning... crazies ahead.
    By ddt in forum Off Topic
    Last Post: 05-12-2004, 12:06 AM
