Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: 2006 tayota tacoma started.
    Jul 2005
    NEW PHOTOS 01-04-07
    NEW PHOTOS 01-07-07
    Subject-
    Toyota Tacoma SR5 4 door 4x4 V6 with 6 speed manual
    Objective-
    Achieve good sound on a budget. Something I have learned along time ago. Yeah you cant beat good stuff and I have used Diamond audio D7, Xtant 604 and 603, butler tube, dynaudio, CDT, Focal, zapco ref. and etc. What I have learned is you can achieve an extremely good sound on a budget. A lot of the pricey hype is just name brand.
    OK I am getting started so bare with me I am going to post photos and specs over the next couple of months.
    So to start I have the following.
    Lilliput 8 inch wide screen
    Seagate Barracuda 7200.1 100 gig hard drive 2.5
    Kingston 1 gig memory
    Windows XP
    Pioneer slim line slot load DVD K07
    Case, motherboard, and power supply to be ordered over the next couple of weeks.
    Up in the air about an amplifier, speakers, and single sub.
    Here are some photos of the 06 dash fiberglass. I wanted to put the slot load DVD in the dash. After measuring and looking It was not going to happen without removing the clock and hazard button. So the photo is the bracket in the ruff. I will sand it and finish it out over the next week. I will post more photos.
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    looks good man. what kind of filler are you using there?
    Apr 2006
    Austin, Tx
    ah **** yea
    Jul 2005
    I used hot glue to help hold the bezel. Then I used a fine hair fiberglass to realy support it. I then used a lightweight body filler. I will sand and use a little more.. After that is done I will use a filler/primer spray that will fill in all the small inperfections. I will then sand it more and more and more. Hope to have it complete by next week.
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    awesome, any pictures of your taco?
    good work, my 98 'runner has a ***** of a dash to work with, everything is so far away and complicated.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
    Jul 2005
    I will take photos of my truck some time this week and post them. It is white with a 3 inch lift, 16x8 aluminum chrome plated wheels, and Goodyear 285/75/r16 mud tires.
    Here are just some ideas I am looking at for the stereo.
    http://www.partsexpress.com/pe/showd...number=295-372
    4 total one in each door with a .15 cub sealed enclosure for each. I will be using multiple baffle rings and 2 inch pvc pipe to make the enclosure
    125hz to 2800hz
    http://www.partsexpress.com/pe/showd...number=264-834
    2 total one in each door front factory location
    2800hz and up
    http://www.partsexpress.com/pe/showd...number=295-460
    1 total in a 1.5 cub ported box tuned to 22 hz
    80hz and below
    I am looking at a couple of amps at this time all 5 channel will use the built in crossovers to do the job.
    Kicker and JBL
    http://www.jbl.com/car/products/prod...=US&region=USA
    this amp only has 12 db xover but should get the job done. I have heard this amp and for the price it is very nice.
    kicker zx700.5 12db xover for the four channels 24 db for the sub
    Just ideas at the time. May change my mind in the process.
    The dayton audio speakers are nice. I built a bookshelf speaker out of the same 6 inch mid and a dayton metal dome and it sounded nice.
    I am thinking of putting something on the highs and mids that will xover at 4500 to 5000 hz. I will have to see. Most drivers I have modeled in my bass box program that will play in this range need an enclosure that is .25 or bigger. There are a couple but the price for two mid drivers pass the total cost of all of the above drivers. And don't forget this system is going to be a budget system.
    Jun 2006
    Denver, CO
    are you building your own crossovers or are you going to let your amp/s handle that?
    Jul 2005
    not sure yet.
    the crossovers in the amp will do the job.
    To build passive will take alot of time. I have harris tech xover and I have built a couple of crossovers off of that. They sounded OK but not great. I have only built one crossover using this program that sounded good and that was a 6 db low pass 12 db high pass using jantzen But parts alone cost me $200.00
    I am looking at budget. I may use 12 db slope passive or I may use an electronic like an audio control 2 way.
    24db is cool but in a car they really do not serve a purpose. The less parts in path of the speakers after the amp the better off you are.
    One other reason I am thinking of using what the amp offers is I am looking at a computer based 1/3 octave 31 band EQ. I have a computer program called true rta and behringer mic. I think I can give the vehicle a flat response using the RTA, EQ, and xover built into the amp.
    I will have to play with it as time goes on. Listening will make the final decision.
    I have been known to buy a product and not like it. I then trash it and try something else.
    But for the time being I am shooting for budget.
    Jun 2006
    Denver, CO
    now you've got me interested in your RTA software. What did that run you? I'm not sure how often i'd use it, but if it were in the neighborhood of not-what-my-entire-rig-costs, i might want to get that before i get the rest of my speakers in.
    Jul 2001
    Isn't that question a bit personal?
  1. My 2006 Civic Install
    By BrentMcGhee in forum Fabrication
    Last Post: 01-31-2008, 12:15 PM
  2. Replies: 2
    Last Post: 05-17-2006, 02:20 AM
  3. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 09:49 PM
  4. Warning... crazies ahead.
    By ddt in forum Off Topic
    Last Post: 05-12-2004, 12:06 AM
