Results 1 to 8 of 8
Thread: 2002 Audi Allroad
    Aug 2006
    2002 Audi Allroad
    First, Thanks to everyone for all of the info that has been posted on here. Without this forum, my Carpc would be crap or non-existant
    Decided to help contribute and document my worklog:
    Car:
    2002 Audi Allroad
    Current Setup:
    Audi Nav+
    Blaupunkt TV/DVD ME3
    Dension Ipod Icelink
    Carputer Upgrade:
    Lilliput 7" touchscreen
    Asrock Micro ATX
    AMD Athlon 2500
    512MB Ram
    500GB SATA HD
    120GB SATA HD
    Slot Loading DVD+/-R
    Belkin bluetooth dongle
    Nokia GPS bluetooth LD-1W
    Belkin 802.11
    Motorola Q w/ EVDO
    Opus 250W Power Supply
    Software
    Windows XP MCE
    RoadRunner
    Mappoint 2006
    iGuidance
    Yahoo Music Unlimited
    Completed:
    Place Tower in trunk
    12V Power to Power Supply
    ACC to Power Supply
    KVM Extension from Trunk to front
    Monitor Plugged into Cigarette Adapter and sitting in console
    RoadRunner Installed and configured
    To Do:
    - Remove Audi Tuner/Nav Unit
    - Wire Lineout of PC to Line in of Audi Amp
    - Shock absorb and mount PC in permanet place in trunk
    - hide wiring
    - Mold Display into Double Din Converter
    - Tap into CAN Bus
    - regain Steering wheel Button functionality
    - find a OBD/VAG Solution
    - find a V1 Integration solution
    Aug 2006
    Wiring through the Audi Firewall:
    Theres already a hole and plug so its really easy to do this part.
    Remove your driver side lower dash:
    - remove two screws in bottom left and bottom right
    - remove screw next to fusebox on left side
    - unplug VAG port and light
    Open Hood
    - Remove rubber stripping that runs horizontally at back of engine compartment
    - Remove plastic cover covering battery compartment and air filter and ECU
    - Disconnect negative and positive leads
    - find rubber nipple next to ECU box
    - Pull with pliers
    - snip hole in rubber nipple
    - feed wiring through. Wire should come out next to streering column inside the car
    - replace nipple
    - complete battery terminal wiring
    Aug 2006
    TouchScreen Dash Modification:
    There is a Metra Adapter available for A6/Allroad platforms. It should be about 30 bucks on ebay.
    Todo:
    Post pictures of process.
    Aug 2006
    Audi Bose Amp Wiring:
    I had the bose package which included an amp for all speakers.
    1. Connecting RCA to amp inputs
    2. Connecting ACC and 12V to amp without Factory HU
    Aug 2006
    VAG / CAN
    I have VAG-COM. might consider skinning it and integrating it into RR
    Really interested in hacking or looking into the CAN. to update climate control, get Speedo speed, update center console display, get remote parking sensor distance info, and regain steering wheel control buttons
    Aug 2006
    Created a Boot Image:
    Preview
    Tiff File
    Boot logo
    Aug 2006
    Wiring through the firewall into the driver footwell
    Aug 2006
    Temporary location of lilliput and CPU
  1. 2002 Audi A6 Bose Integration
    By bobbydude78 in forum Car Audio
    Last Post: 11-05-2007, 10:07 PM
  2. 2002 Audi A4
    By Janis Petke in forum Show off your project
    Last Post: 07-31-2006, 09:26 PM
  3. Audi Allroad install
    By AudiFan in forum Show off your project
    Last Post: 02-09-2006, 01:38 PM
  4. 2002 Audi A4 ... Version 3
    By reda4 in forum Show off your project
    Last Post: 05-12-2004, 04:26 PM
  5. 2002 audi A4
    Last Post: 04-26-2004, 08:46 PM
