Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 74
Thread: 2001 Pontiac Trans Am
  1. #51
    Dec 2007
    Gonzales,LA
    First off nice setup and srry bout ur luck with it all.Also congrates on getting married.
    What OS u running?
    Also what has ur latest boot time been from cold start?Not hibernate.
  2. #52
    Maximum Bitrate redls1bird's Avatar
    Feb 2006
    Atlanta Ga.
    Thanks chevy! Im using Tinyxp for a os. It was quicker when i got it, with nothing on it. Just roadrunner and winamp, i could boot to music in about 34 sec. Now with Digitalfx 2.0 as a skin, bluetooth, wireless internet, gps and everything else, its boot to music in about 55 seconds. My way of combating this (after in bootvis and everything else i can think of) is to hook my psu up to an output on my remote entry system on my car to the same input as ign wire, with a diode. That what when i unlock my doors, it starts the boot process hopefully shaving off 10 seconds or so. Its only theory right now, but im pretty confident i can get it to work how i want.
    EDIT: Bootvis shows cold boot takes 34 seconds, and winamp is running by 37 seconds.
    Car Pc progress meter:
    [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
  3. #53
    Dec 2007
    Gonzales,LA
    wow i really need to see hwat is going on on my side my cold boot with jus rr and winamp also is roughly around 1 1/2 mins.No added programs to help though.
  4. #54
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Hibernate should help drop the time a little.
    Remote starting the PC is very handy as well. I have a long range remote with some aux outputs and a custom SDC, but it should be easy enough with just the unlock. It's negative trigger (off one of the far right wires on the BCM) so you could use a relay if you want to reverse it for something that takes a positive pulse. If nothing else, make a 5-10 minute timer that simulates ACC/IGN (with 2 doides going into the SDC) before you get in.
  5. #55
    Feb 2006
    Atlanta Ga.
    From the moment i touch the power switch to hearing sound is 22 seconds in hibernate. Thats not to shabby. I have no testing though to see if my usb components will make it back from hibernate and function properly. Because of this, i have told myself i may have to cold boot each time. Ive accepted it at this point.
    What are your system specs chevy? Im running an old Intel board with onboard sound and video, 512 mb ram (maxed out) 1ghz PIII processor. Do you have an option in your bios for quick boot? or anything like that? It made a pretty good difference on my machine.
    My worklog
  6. #56
    Dec 2007
    Gonzales,LA
    My specs
    Via m10000 1ghz
    512 mb
    4gb CF card (133/x )
    After some work in bios,disabling all devises from starting but the CF card I still get slow boot times.Now from standby (s3) I start back up in less than 10 seconds.I think I'm gonna use S3 for my start up.I haven't tested to see what power its pulling in S3 but I belive it is low enough plus the m1-ATX will shut down the CPU if the battery gets to low.
    (srry I'm on my BB so proper text is a issue)
  7. #57
    Feb 2006
    Atlanta Ga.
    No prob about the BB. Ive noticed on my system that in quick boot mode it seems to skip the ram test. If i leave it uplugged for long periods of time, or remove the ram, it will do a full test on the 512 at startup and that adds considerable time. Is your testing the ram everytime?
    My worklog
  8. #58
    Dec 2007
    Gonzales,LA
    Not sure. I didn't see a quick boot that's why I disabled all. The bios isn't what hurts me that's about 10-15 seconds at most, the windows XP boot screen is what kills me. But I think if I did minilogin that would help that alot.
  9. #59
    Feb 2006
    Atlanta Ga.
    Have you tried bootvis? Its very helpful and informative. It lets you see (via a bar graph and line graph) whats going on at each stage of booting and drivers as well. Download it and give it a shot. If you need any help using it let me know.
    My worklog
  10. #60
    Feb 2006
    Atlanta Ga.
    Ive been debating mocking up my install in the car and testing it out for bugs and what-not. I was waiting til I had everything, but thats just gonna draw out the process longer. I think im gonna pick up either a m2-atx or a m3. I just dont like the idea of having to mount the m2atx, but hell its no big deal Also, in a couple of years i plan on doing a complete double din install, mother board and all, so i dont know what my power needs will be.
    My worklog
  1. Replies: 11
    Last Post: 03-15-2007, 07:16 PM
  2. Replies: 6
    Last Post: 04-24-2006, 12:18 PM
  3. 2001 Pontiac Sunfire
    By Moneyfink in forum Worklogs
    Last Post: 06-24-2005, 04:59 PM
  4. 2001 Pontiac Firebird TransAm and a DWW-7VGA?
    By WWE-TicK in forum LCD/Display
    Last Post: 02-12-2005, 10:16 AM
