Results 1 to 10 of 14
Thread: LCD retrofitted into OEM housing
    Mar 2005
    Heres my progress so far, its taken alot of work to get it to look this OEM, with still alot of work to go, ill definitly have it in during the next month. Heres some shots so far of the LCD:
    Stock radio:
    Here is the screen sitting next to the OEM tape deck cage:
    [img]
    Here it is almost done:
    Heres a picture of my car:
    and the interior (retrofitted the whole interior with blue LEDs):
    What can I say, I love Volvos:
    Volvo 740 with 5.0 mustang conversion (totaled)
    Volvo 740 stock (sold)
    Volvo 940se (sold)
    Volvo 850 T-5R yellow (sold)
    Volvo S70 T5SE
    Volvo C70
    Volvo 850R with a long list of mods
    Mar 2005
    Forgot I should have added my car. Can someone add Volvo 850 T-5R before the words in my title.
    Volvo 940se (sold)
    Volvo S70 T5SE
    Volvo C70
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Very nice! Are you going to add a plastic bezel around it? Also, I couldn't tell how you supported the LCD. It's going to bounce around alot with car movement, plus has to support you pushing on the touchscreen.
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    Mar 2005
    I have plans for a bezel, but you will have to wait for that. I stuck the screen in there with double sided foam tape.
    Volvo 940se (sold)
    Volvo S70 T5SE
    Volvo C70
    Dec 2005
    Raleigh, NC
    Is that a 7" widescreen or an 8" widescreen? I've been debating which to get to fit into a double din setup that would also be custom.
    Mar 2005
    its a 7" xenarc screen
    Volvo 940se (sold)
    Volvo S70 T5SE
    Volvo C70
    Maximum Bitrate Jarrod's Avatar
    Jan 2002
    Melb, Australia.
    Nice work. I did very much the same thing with my install I ended up making a frame for the LCD out of plywood, then moulding that to the OEM housing using plastic bond stuff to act as the front bezel. Then did a lot of sanding, painting, etc.
    As for holding the LCD in place, I screwed two wooden noggins into the top and bottom of the front of the housing (behind the bezel) and left just enough room to squeeze the LCD and touch screen inbetween the bezel and the noggins. Then I screwed the original LCD mounts (little metal things) into the noggins and they held the LCD in there nice and tight.
    Wish I had a photo to show...
    Jarrod - Holden VX S!
    Jul 2006
    Nice car! Can you stuff the whole computer in there? I would bet you could if you played your cards right.
    Mar 2005
    mabye, im using a laptop though, so no dice.
    Volvo 940se (sold)
    Volvo S70 T5SE
    Volvo C70
    Das
    Das is offline
    Constant Bitrate Das's Avatar
    Aug 2004
    Texas
    Where did you get the blue leds from, I would like to do that to mine.
  1. FAQ: Transflective Technology
    By nameeri in forum LCD/Display
    Last Post: 06-06-2006, 11:26 PM
  2. Lcd grounding issue, can't get rid of flickering
    By diskey in forum LCD/Display
    Last Post: 05-23-2006, 04:16 PM
  3. Sebring LCD Housing Fab done.
    By Jcarere in forum Fabrication
    Last Post: 01-04-2006, 02:32 PM
  4. IH001 Empty Indash LCD housing - Digital ww
    By Pabs in forum LCD/Display
    Last Post: 10-01-2004, 03:45 PM
