Results 1 to 10 of 14
Thread: New Audio Install! STEG amps, Focal 40KX Sub.
    _
    Mar 2004
    Little Elm, Texas
    Click on any picture to see a larger image...
    Amp Rack:
    For more pictures: Linky!
    Recently, we decided to make a switch from the Audison LRx amplifiers we had been running to the new STEG K series amplifiers.
    This meant that we had to redo the back end of the car since these amps were different dimensions.
    We've had really good success running the tubular style am racks. It's kind of become our signature, so we decided to take it a step further.
    Since these new STEG amplifiers are a bit beefier and more industrial looking than the Audisons, we wanted to do them justice.
    2 1/4" 16 gauge steel pipe would do the trick!
    One problem, how do you bend pipe like this? If we wanted precise bends, of a more extreme radius, we were fine. However, that's not what we wanted. What to do? How to get a very gradual bend in a 2 1/4" 16 gauge steel pipe?
    We went to muffler shops, we went to a custom chopper shop, we went to metal fabricators, no dice anywhere.
    So....
    We decided to notch the pipe every 3" or so at a 5 degree angle. Then we went back at each notch at a 0 degree angle and cut the notch out. We did this with a metal cutting blade on our table saw.
    This made bending the pipe to a desired radius possible and extremely easy.
    Voila!
    x2 for the two pipes that we needed.
    Now came my favorite part! Welding it all back together. This should have really been done with a stick welder. However, those are fairly expensive. The welder we have cost us $350. It's a great little hobbyist welder, no doubt about it.
    The welds were everything BUT pretty. Filling 1/4" gaps with 0.6mm filler wire on a pipe isn't an easy task. Some people say that welding plate steel to thing pipe is very hard. If that's the case, this is even harder. We have the capability to use 0.8mm filler wire, but the 6mm was already loaded and threaded.
    Now came the time to grind down all of those hideous welds.
    Thanks to our friend David for helping on this part. I think he just enjoyed hacking away at something for a while. You would be surprised how soothing it can be!
    Trying to bend the 1/8" plate steel so it will fit under the trim panel isn't easy.
    Spot welding the tubes in place and making sure everything will fit.
    With the notches cut out for the amps to sit in.
    With the braces for the amplifiers welded into place.
    This is what a cooked drill looks like! This happened while trying to drill the holes in the end of the amp rack for the wires to pass through the end plates.
    Bondoed to make the amp rack smooth.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Sub Enclosure:
    Since we're redoing the amp rack, we decided to go ahead and rebuild the sub enclosure.
    We only had about 2.75 cu. ft. in the last enclosure. This sub needs 3.25ish cu. ft. and a 4" diameter, 6.5" long port to be in an ideal enclosure.
    So we decided to figure out a way to achieve this and still be able to do the tubular amp rack like we like so much.
    Normally we would apply the duraglass and fiberglass from the bottom side, but with such a flat surface to work with, we decided that it would be more work to apply from the back, so we did it from the top.
    With the DuraGlass on. There's about 2 gallons of this stuff on and in the enclosure.
    Here's Monte sanding on the enclosure. In order to fill the gaps along the sides and the front of the enclosure and the amp rack and the car, we had to build up a bit of Rage Gold.
    Last night I finished off the enclosure, now we need to finish the amp rack and everything should be ready for paint!
    Jan Bennett
    Apr 2006
    Dallas, Texas
    Wow, I didn't get a chance to see the welding. I missed out! But laying the fiberglass with the resin was fun! I can't wait to see the final results.
    _
    Mar 2004
    Little Elm, Texas
    I have a nice 'sun burn' on my left knee from wearing shorts while welding.
    That's one reason my eyes were bothering me yesterday.
    Was about 2 hours SOLID of doing nothing but welding. We have crappy masks too and it was dark outside...it just sucked.
    I can't wait till we have a real shop...lol
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    updated with more pics of the amp rack progress, including a burned up drill!
    Jan Bennett
    Das
    Das is offline
    Constant Bitrate Das's Avatar
    Aug 2004
    Texas
    Yay, I liked the old setup a lot, but I can't wait to see when you're through with this one.
    We're going to do mine next right?
    _
    Mar 2004
    Little Elm, Texas
    hehe - if you're willing to pay for it, sure!
    Jan Bennett
    Constant Bitrate stealinfool's Avatar
    Dec 2005
    Orlando
    Lookin' good. I'm happy about the "pipe racks", they looked great on the last install. Keep it up.
    _
    Mar 2004
    Little Elm, Texas
    updated pics of the amp rack with bondo
    Jan Bennett
    Das
    Das is offline
    Aug 2004
    Texas
    you bondo'd the amp rack? I didn't know you could do that...
  1. Need help with audio install
    By Zebelkhan in forum Car Audio
    Last Post: 01-24-2005, 04:15 PM
  2. Replies: 19
    Last Post: 12-04-2004, 05:37 PM
  3. XMDirect Digital Audio Project ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 09:26 PM
  4. favorite car audio install information sites?
    By fluffy2097 in forum Off Topic
    Last Post: 11-22-2003, 12:07 PM
  5. Car audio install idea/tips [PIC]
    By vickumar in forum General MP3Car Discussion
    Last Post: 10-08-2001, 11:05 AM
