Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Zach's 01 SS Camaro Carputer Install
  1. #21
    Oct 2005
    Hou. TX
    Quote Originally Posted by scotty562 View Post
    I think it will work underneath the plastic part underneath my rear hatch. I'll test it out tomorrow.
    Is the rear better or can you mount it up front? (I don't know where your laptop is)
    In the rear you might try next to the jack. It's more centered and it only has plastic and carpet above it. In the front, under the dash pad is best.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  2. #22
    Aug 2006
    Central PA
    Quote Originally Posted by JasonWW View Post
    I actually never did post pictured of where I mounted the laptop. I'll have to change that. I put the laptop inside of one of the boxes that they ship laptops in and I modified it so all of the wires can come out of it. It has the white plastic like material protecting it which absorbs most of the vibrations. I then put the box in place of the spare tire and jack. It fits perfectly and I haven't had a problem with it yet. I would like to find a way to fit the spare tire back in there though... I usually don't go far so I haven't been too concerned about it.
    I didn't get to drive the car today like I thought I would and I probably won't drive it again until Friday in which I'll be driving down to see the lady. I'll test both locations you mentioned. Right now I have it where the jack would have been.
    I can mount it either in the front or the back. I have a usb hub in the front. If you think the front would be better I'll put it up there. When you say "under the dash pad" are you referring to the space right behind the stock radio?
  3. #23
    Oct 2005
    Hou. TX
    If you pull both a-pillar covers the big pad that has the air grills in it pops off. There is room under there. The actual dash may have a steel liner, I'm not sure, but the forward dash pad is just plastic and you have the whole windshield above it.
    CarPC's in F-bodies
  4. #24
    Nov 2006
    Arizona
    SS Car Computers
    Hey man i've got a 2001 SS also, I was wondering myabe you could post some more pictures, see what eachother have done maybe get some ideas
  5. #25
    Aug 2006
    Central PA
    Yeah sure, is there anything in particular you would like to see?
  6. #26
    Aug 2006
    Central PA
    I bought an auto power on module and I wish I would have done it a LONG time ago. You can check it out HERE.
    The only problem I had was the jack that came with the unit did NOT work. I don't know if something was wrong with mine or what. I had to remove the jack and wire the yellow and green wires to my button directly. Support is also lacking... I emailed as per the instructions that came with it and I never heard from the guy. It did ship out very quickly though. Also, now that it's working I love it! It was worth every penny.
    I'll be adding the shutdown controller soon as well. You can check it out HERE.
  7. #27
    Aug 2006
    Central PA
    Well I got frustrated enough with my carpc last year to yank this bad boy out. I still have the touch screen in. I had too many problems with my laptop and running a usb cable the length of the car. My future plans are to build a pc in behind where the head unit would normally sit and start over. It'll be better this way.
  8. #28
    Nov 2006
    Arizona
    I have had enough of mine too i love it but it seems that I'm tinkering more then listening to music.
    Hope you don't mind but I am going to post a link to a custom bezel that i am trying to sell it has a 8" Dynamix screen in it as well as a pioneer dvd drive.
    2001 Camaro SS #2070
  1. 1990 Cherokee carputer install
    By MAXXMODDER in forum Show off your project
    Last Post: 05-20-2004, 08:11 AM
  2. My 03' Maxima carputer install
    By htsea in forum Show off your project
    Last Post: 05-10-2004, 02:11 AM
  3. Need help with install of carputer using a laptop...
    By slimcubby in forum General Hardware Discussion
    Last Post: 04-27-2004, 01:55 PM
  4. Replies: 2
    Last Post: 04-26-2004, 07:29 AM
  5. Ready to install Carputer
    By petera in forum Power Supplies
    Last Post: 01-05-2004, 12:52 PM
