Results 1 to 8 of 8
Thread: Ford Probe GT - Motorized LCD
    Oct 2005
    Well it has been a long time coming, and there is still a lot of work to do - but I am really happy with the progress so far. My intention was originally to do a complete stealth install of a LCD monitor but for now ( ) I went for something in between. I wanted something I could walk away from and have it not scream look at my nice stereo.
    So the process started taking design cues from the cover to the 350z, and a motorized LCD. I also wanted a variable position LCD to avoid sun reflection. In the Ford Probe the A/C controls are a combination of electrical, physical, and vacuum so it makes relocation or fabricating a switch system difficult. There have been numerous successful installs where the HVAC controls were relocated. I was not happy with this idea, or loosing my vents - so I figured why not recess them hidden behind the LCD. With the long term goal being to have a fully digitally controlled system (it’s on its way soon hopefully!).
    So, first here is a picture of the car.
    http://www.supermotors.net/vehicles/...y/media/434634
    The cars stock interior (borrowed internet image)
    http://www.supermotors.net/vehicles/...y/media/434626
    Now the fun begins, cutting away the stock supports. There is something absolutely perversely fun in taking a hack saw to your dash.
    http://www.supermotors.net/vehicles/...y/media/434627
    Big hole now
    http://www.supermotors.net/vehicles/...y/media/434628
    Then I modified the stock radio bezel to accommodate the needed opening. The button controls for the fog lights, defroster, etc. were moved down to provide the required opening. All the red on the bezel is from a "hot" mix of bondo to remove all the factory moulded bumps. I haven’t decided if I will leave it smooth, or recreate the factory look. With all the required sanding and shaping a flat surface IMO is required to have a fresh start for whatever direction you go.
    http://www.supermotors.net/vehicles/...y/media/434629
    I made a frame from laser cut pieces of acrylic to form some of the support and guide rails for the eventual lcd and motor. This thread is cross posted on mp3car.com and probetalk.com so some of you may not be familiar with the use of ABS sludge. Essentially you take shredded ABS and put in acetone. The result is a sludge of ABS that can be poured. This method is infinitely better then bondo as the ABS sludge will actually fuse with the ABS of the stock radio bezel. No chance of cracking as once dry the 2 pieces are as strong as the original one. If you want to use this method check out mp3car.com for some excellent write-ups. One important note is to make sure you have bare ABS that is free of paint. Paint will prevent bonding.
    http://www.supermotors.net/vehicles/...y/media/434647
    Another picture from the backside, showing a second pouring of the ABS sludge, and the frame for the LCD.
    http://www.supermotors.net/vehicles/...y/media/434630
    Then after several thin layers of ABS sludge, a light coat of bondo, more sanding you get something like this.
    http://www.supermotors.net/vehicles/...y/media/434653
    After Primer.
    http://www.supermotors.net/vehicles/...y/media/434654
    Next I made a cover out of acrylic, then laser etched and sandblasted a logo onto the cover. I will be replacing the cover with a new one once I finalize paint. It will perfectly match the rest of the bezel. The picture is after install with the door closed. The paint is semi-flat black. I am not entirely happy with the finish, and there is a small stress crack from me being far too aggressive with the install. Also need to fix slight tolerance issues due to the paint, and make a cubby hole for the opening at the bottom. A
    http://www.supermotors.net/vehicles/...y/media/434633
    With the cover door partly open (non-motorized). The piece of red tape is only temporary.
    http://www.supermotors.net/vehicles/...y/media/434635
    Now for the fun part, with the push of an originally factory switch for the headlights. You get motorized lcd to fold down to a preset position. The position has preset travel limits with the button, however there is a secondary control so I can angle the LCD at any angle along its travel to minimize sun reflection.
    http://www.supermotors.net/vehicles/...y/media/434636
    And Voila! My hidden A/C controls. The screen still has its protective sheet on it while I finalize the install so forgive its appearance. Eventually it will be painted to color match the bezel. With the release of the button, the screen folds up and all is well. Note: The screen appears slightly tilted, it is undergoing final adjustment as we speak.
    http://www.supermotors.net/vehicles/...y/media/434638
    So I know there will be a lot of questions concerning how the LCD was motorized, but I will reserve a space to follow up on this in a future post. Needless to say, be patient it is a very simple, and cheap (~60 bucks if you have access to materials, equipment) design that took a lot of redesigning and several prototypes to make work. Motorization and cheap are 2 words usually not meant to go in one sentence. Your comments, questions, advice are welcomed.
    Oct 2005
    Please reserve for updates, and how-to on motorizing the LCD
    Oct 2005
    Reserved for additional info.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    that is pretty slick! nice work
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Oct 2006
    how did you motorize the lcd?
    servo acutator?
    Oct 2005
    Actually used the track and gear set from an old computer CD player. Worked great, just need to replace the motor for something with a little more power. There was not a lot of interest in the original post, so never bothered putting the time in to finish it.
    Oct 2006
    can you post some pics of the assembly?
    and also can you tell me how to make the drive work for this job?
    thanks for the help.
    i only have a 1 and 1/2 din slot in my car
    and i cant move my ac controls to anywhere but the dash.
    so i want to do this so i can keep the ac controls.
    Newbie lalakers's Avatar
    Apr 2006
    OC, California
    where r u located at i got a probe all fixed up ze'ed up
    LAKERS BABY
  1. MOtorized LCD that flips down?
    By AdamChrap in forum LCD/Display
    Last Post: 02-01-2006, 10:16 PM
  2. What I want in a Doube-DIN motorized LCD.
    By RPM_VR4 in forum LCD/Display
    Last Post: 11-13-2005, 08:04 PM
  3. Can you buy motorized LCD brackets?
    By pigseye in forum General Hardware Discussion
    Last Post: 12-27-2001, 12:43 AM
  4. LCD in DIN and Ford Mach 460
    By smashr2k in forum General Hardware Discussion
    Last Post: 09-21-2001, 09:33 PM
  5. motorized lcd cover
    By new0deal in forum General Hardware Discussion
    Last Post: 11-08-2000, 05:50 PM
