Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: MOD Project: Infiniti G35 MacMini
    Oct 2006
    MOD Project: Infiniti G35 (SkyLine) MacMini holder for car pics, project goals, ect...
    (when I get unlazy to actually document the plans I have in my head)
    Stock pictures... before the install:
    Oct 2006
    Infiniti G35 Carputer mac mini led mod
    The stock Intel Mac Mini has a white Power LED. Because I want the mac mini to look "stock" and right at home in my G35's dash; I'm going to spell out the details on how to mod your mac mini's stock LED color.
    After many google search attempts; I have not seen anyone publish a tutorial on how to change the color of the LED in your mini. I hope the Mini Modder's enjoy this how-to.
    Please keep in mind that you take all responsibility for implementing the LED mod on your Mac Mini. It will void your warranty so keep this in mind BEFORE attempting this mod. Neither Zittware nor WizD is liable for voiding your warranty.
    First you need to dissemble your mac mini to get access to the white LED.
    I did this by following two tutorials:
    First being the disassembly video @ Smash's world. I elected to use the putty knife method instead of the wire method. The putty knife seemed like less effort despite the risk of scratching the mini's body. I used a Warner 1/2" Flex putty knife purchased from lowes. It had the thinest profile of all putty knifes at Lowes.
    Once I had the top cover off my mini; I began carefully disassembling the mini using's step-by-step guide.
    I stopped before removing the ram or the hard drive.
    You need to remove the black tray assembly containing the cdrom and HD; but do not need to remove the CPU or Ram from the motherboard.
    Oct 2006
    Now the real fun begins.
    Let's mod the MacMini power LED:
    Materials needed:
    • High End SMT (surface mount technology) capable soldering with fine SMT tip
    • desoldering wick
    • SMT 1206 LED color of your choice
    • Datasheet for the LED you selected. Need forward voltage drop spec @ 20mA.
    • SMT 604 resistor @ 56ohms.
    • hobby knife with newish triangle blade.
    • solder
    • uber soldering skillz for SMT devices
    1) Remove the LED board
    Remove the white LED's mini circuit board by gently pulling the black hard tape apart at the rear of the assembly. I used a hobby knife to start removing the tape. Be gentle; the black tape easily rips despite being thick.
    Once the tape is free; you'll have a small circuit board double sticky taped to the back of the black housing. Use that same knife to gently pry the circuit board from the tape.
    Take care with the wires attaching to this board. They are fragile and will break easily.
    2) Mac Mini's LED circuit board w/ "foam" light blocker
    Here's a picture of the circuit board removed. The black foam is adhesive backed; which is how it attaches to the circuit board.
    I beleive the purpose of this foam is to provide a spacer to secure the circuit board in the assembly... maybe to prevent "rattle". Apple certainly knows how to spec quality assemblies.
    Gently remove the adhesive foam using a hobby knife. Take care to remove with the adhesive intact on the foam (not circuit board) so you can reuse it during reassembly.
    3) Desoldering time
    Notice the white diode labeled D1. and the plus (+) symbol.
    Using an SMT tip; desolder the diode at D1 using a solder braid.
    Clean up the diode pads using solder braid.
    Rotate the wires by to the backside of the circuit board; one at a time; to ensure you don't accidently wire the board / LED backwards. I used a solder braid to remove the solder; then resoldered on the non component (or non copper) side.
    4) MacMini's HH LED prep
    Using the hobby knife; scrape off enough solder mask to mount your desired color. The author used a 1206 SMT LED - Orange from Digikey - A Stanley AA1101W.
    For our calcuations; we are going to assume the forward drop of the stock white LED is a typical 3.6V. Assume typical LED currents of ~20mA.
    Since we are using a lower voltage LED; we need to put a current limiting resistor (RLED) into the circuit to "drop" some voltage. Using some electrical engineering - Kirchhoff's voltage law's_circuit_laws#Kirchhoff.27s_voltage_law
    ; we know that the sum of all voltage must be zero.
    0 = Vwhite + Vr.led + Vled
    (a) Vrled = Vwhite - Vled
    Kirchhoff's current law's_circuit_laws#Kirchhoff.27s_current_law
    we know that the current through our LED must be equal to the current through our new resistor RLED.
    (b) Ir.led = I.led = 20mA
    Using Ohm's Law's_law
    we can solve for the value of RLED:
    I = V/R ; solving for R
    R = V/I
    RLED = Vrled / Ir.led ; knowing (a) and (b) yields:
    RLED = ( Vwhite - Vled ) / ( I.led )
    From our new LED's datasheet we know that VLED = 2.2V; so:
    RLED = ( 3.6V - 2.2V ) / ( 20mA) = 70 ohms
    The closest resistor value the author had in 604 package was 56ohms; so we will use 56ohms in the remaining steps.
    NOTE: If you are going to replace the LED with a newer color like Blue, bright green, or uv... note that the forward voltage of these LEDs is closer to the original White LED. As such; you will *NOT* cut the traces below or solder in a 56ohm resistor as calcuated above. IF IN DOUBT; check your datasheet for it's typical forward drop @ 20mA.
    IF your using a standard low voltage LED (red, yellow, orange) with a Vdrop ~2.2V continue. Else skip the next step cutting the trace below.
    Cut the long trace on the Kathode (+) side of the LED. Make the cut wide enough to fit a 604 SMT resistor.
    Oct 2006
    5) Mac Mini's HH LED modified
    Solder the new 1206 SMT LED to your new landing pads; over the existing hole.
    If using a ~2.2V LED; solder your 56ohm 604 smt resistor to the cut trace.
    6) Mac Mini's HH LED reinstalled
    Reattach the black foam spacer over the new LED - allowing the LED to shine through the hole in the foam.
    Reinstall the LED board into it's housing.
    Make sure to align the LED to the hole in the black tape.
    Gently manuver the LED boards wire out the original hole.
    Reassemble the black tape around the modified HH LED board.
    7) Reverse your disassembly; returning the mac mini back to it's assembled form. Take care to reassemble everything.
    Here's the final look; complete with an Orange power LED which will match nicely with the G35's orange iluminated dash.
    Oct 2006
    Mac Mini Modding: Disabling the internal speaker
    Lots of work has been done behind the scenes to test the mac mini before the G35 is disassembled for installation... here's some of the highlights.
    Before reassembling the Intel Mac Mini; I finished up some last minute issues.
    First; To use the mac mini in my car; It was desirable to disable the internal speaker of the mini. To do this; simply remove J23's connector on the back board which connects to the CDROM. I left this connector taped to the black plastic of the cdrom assembly.
    Next; To remote power up the mac mini using the Carnetix CNX-P1900 DC-DC supply; I put the supplied power button "y" adapter and routed the external connector out of the rear fan hole. I later changed this to exit on of the bottom vent holes.
    I began wiring the P1900 supply to my test ATX powersupply... with a simulated ignition. No pictures here; but can post a diagram if there is interest. This was done to work out the kinks of the power supply, Mini, and 700TSV lcd before it's installed in the G35.
    On tap tomorrow is a trip to Radio Shack to get a DPDT mini switch and a 1/4" audio plug for the continued installation.
    Oct 2006
    It's ALIVE
    Austin Modders met at my house this past saturday to begin the task of installing the MacMini into my G35.
    After a long weekend... and several nights after work; I'm proud to present that the G35 MacMini project is alive and playing MP3s... dishing out gps coordinates via Google Earth and Earth Bridge.
    First a Stock picture... before the install:
    And here it is after the install:
    Yeap... here's the car when everything put away. still looks stock - which was ONE of the goals of this project.
    Bet your thinking: "ok smart ash... wtf are you trying to pull"
    nothing ... I swear!
    The touch screen is located in the same location as the stock navi screen. Closeup of the's 700TSV touch screen installed in the center console. Plans are in place to purge the housing of it's brushed aluminum bezel... but you'll have to wait to see that! Later in the project.
    Onscreen is Google Earth running Earth Bridge... and Winamp Playing mp3s in the foreground.
    Why you might ask? Because has yet to honor it's $50off coupon for Streetdeck for my September order.
    But... Where oh Where is the MacMini?
    The same location as the stock Navigation system.
    Ofcourse you can see a closeup... you needn't ask!
    Macmini installed in the G35's navi cubby uses a DigitalWheelz Din Converter from G35 was secured in the DIN converter using #6-32x3/8" standoffs on both sides.
    The modified CarNetix CNX-P1900 PSU is mounted on the right side.
    The left side is reserved for the USB2.0 hub... to be installed later.
    All of this will be polished off with a custom cnced front panel when I get a chance.
    More later...
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    wow, looks really good, it came out nice. what are you using for the audio? Is it connected to the stock HU?
    btw, what camera did you take thos pictures with? They came out great.
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Oct 2006
    Quote Originally Posted by Quattro View Post
    I'm using a PAC AAI-NIS2 to connect to the stock head unit. Which is why I'm really miffed that I can't get [email protected] to return my email about getting my $50off of streetdeck... As you can see from the install; I bought over $1000 from them to get this puppy off the ground!
    I bought a first generation Cannon Digital Rebel several years ago... I love the camera. Did a good job of shooting in the dark tonight; huh?
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Hey, zitt, looks really nice. I've got a custom PC in my G; I love the G, it is such a sweet car, and you did it justice with your install
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
    Oct 2006
    Time to report on the weekend activities.
    As I stated in a previous post; one of the goals is to have the g35 look stock when the toys are put away. To this end; it was desirable to mount the override switches in an inconsipucious place. That place: The ashtray.
    Step one involved removing the ashtray from the g35... which gives us the following stock ashtray:
    The switches will be Bulgin Vandal resistant switches. Ring type with Amber and White LEDs. The Amber LED Switch will control the PSU via remote powerup on J1 Pin 1 of the PSU. The White will give me access to the MacMini's powerbutton which cannot be reached as it is in the dash.
    I also integrated a "kill" switch to remove the PSU / MacMini from car power. IE long trips where the car will set for long periods of time. This switch is a Eswitch rocker switch RR3112 LBLKBLKYEL SPST with a 12VDC Amber LED. It interrupts the battery power to the PSU.
    Ofcourse I needed a way to mount these beasties on top of the ash tray; so I went through several revisions to come up with the following design:
    This is the most optimal configuration due to the space contraints inside the G35's ashtray.
    This design was then ported to my CNC where it was cut out of 0.1" Aluminum plate.
    Here are some pictures I took of a previous revision while CNCing and test fitting.
    G35 Ashtray switch insert (cncing):
    G35 Ashtray switch insert (done):
    G35 Ashtray switch insert (test fit):
  1. 1998 Infiniti QX4 Project
    By Mick300ZX in forum Show off your project
    Last Post: 02-28-2008, 01:51 PM
  2. OEM GPS mod. Writeup + Pics
    By IntellaWorks in forum Hardware Development
    Last Post: 07-04-2006, 03:59 AM
  3. FAQ Tutorial: Wire/Pin Mod for Mobile Athlon
    By Quattro in forum The FAQ Emporium
    Last Post: 05-06-2006, 01:50 PM
  4. My "RoadStarr" Project ... Still In Progress...
    By Fraychild in forum Show off your project
    Last Post: 06-15-2005, 08:52 AM
  5. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
