Results 1 to 4 of 4
Thread: Ford Mondeo (reserved)
    Newbie D4niel's Avatar
    Aug 2006
    Essex
    (RESERVED - No banter) Updated 09112006
    Component list
    Bluetooth USB dongle - 6.99 purchased
    Wireless Wifi PCI card - 19.99 purchased
    Nano mini USB keyboard - 14.99 purchased
    4 Port USB 2.0 Hub with Power Adapter - 6.48 purchased
    23 in 1 ALL-in-1 Card Reader/Writer - 5.14 purchased
    DVB T digital tv/radio USB 2 - 19.99 purchased
    Bluetooth GPS receiver - 39.99 purchased
    FM transmitter 11.99 purchased
    512mb RAM DDR 533Mhz - 39.99
    Jetway J7F4K 1.5GHz C7 Mainboard - 105.00
    Noah Mini-ITX Case - 72.24
    Western Digital WD2500BB 250GB 7200RPM ATA/100 2MB Cahce - OEM - 48.87 purchased
    LinITX Plus 7" Widescreen VGA/Composite Monitor with Touchscreen - 179.00
    Spent so far: 125.56
    Software
    I have already got these titles;
    Windows XP Pro
    Autoroute 2006
    Winamp 5.3
    I need to get the following;
    Streetdeck
    Whats being purchased next
    Carpc layout
    I have got a 48x cd-rw drive already which will not fit this case. Its not a problem, i only intend to install Windows Xp pro once and any other media can be beamed through my home wireless network.
    Aug 2006
    Essex
    Tested fm transmitter with ipod in current car which has 2 power inputs
    Test 1: With power input at front of car; FM transmitter also transmitted interferance from the car, clearly a poor earth.
    Test 2 : Tried second power input in the boot; No interferance from the car, transmitted clearly. Not the best sound quality but will allow easy sound input into standard car stereo.
    Aug 2006
    Essex
    Hard drive
    Originally I was going to have a 40gb Seagate laptop drive which is more resistant to bumps and bangs. However the choice of case allows for a conventional 3.5" hard drive to be installed. I know that this hard drive is not going to be as resistant as the laptop unit, but at 48.87 for 250gb, its got to be done.
    I have ordered a Western Digital WD2500BB 250GB 7200RPM ATA/100 2MB Cahce - OEM. The car its going into has not got sport suspension and most of the roads I am using are in good condition.
    Aug 2006
    Essex
    A big change in the hardware?
    I have got about 400 / $770 to spend on the car pc its self. I could continue with the current plan or go for a mac mini with a Carnetix CNX-P1900 V2 140W Dual Output Power Regulator which comes with all the relevant power connections. I like the look of the macmini, very tidy and very powerful for the price too.
    Mac mini
    Heres the spec :
    399.00
    1.66GHz Intel Core Duo
    512MB (2x256MB) 667MHz DDR2 SDRAM (PC2-5300)
    Option: up to 2GB
    60GB Serial ATA
    Option: up to 160GB
    24x Combo Drive (DVD-ROM/CD-RW)
    Intel GMA 950 graphics processor with 64MB of DDR2 SDRAM shared with main memory
    DVI output port with support for VGA, S-video, and composite video connections via adapter4
    Connects to external display with digital resolution (DVI) up to 1920 x 1200, analog resolution (VGA) up to 2048 x 1536
    Four USB 2.0 ports, one FireWire 400
    Built-in speakers, optical digital audio output/headphone out, optical digital audio input/audio line in
    Built-in 10/100/1000BASE-T (Gigabit)
    Built-in 54-Mbps AirPort Extreme Wi-Fi (802.11g); built-in Bluetooth 2.0+EDR (Enhanced Data Rate) module
    Apple Remote
    DVI to VGA adapter
    5.08 x 16.51 x 16.51 cm
    1.31 kg
    If i did go for the above unit, the only peripherals I would have to add would be;
    *Nano keyboard
    *Mouse
    *23in 1 card reader
    *4 port usb 2 hub
    *DVB-T usb 2 tuner
    *Centrix 1900 power supply unit
    *LinITX 7" touchscreen
    Mac Mini Layout
  1. Ford Mondeo CarPC!
    By jeroenvw in forum Show off your project
    Last Post: 12-31-2012, 10:50 AM
  2. Euro (UK) Ford Mondeo ST200 indash install
    By jonargraig in forum Show off your project
    Last Post: 04-17-2008, 10:31 PM
  3. Ford Mondeo 2.0L 1996 stv.
    By Stranded in forum Show off your project
    Last Post: 07-24-2006, 09:22 AM
  4. Ford Mondeo --- is it compliant?
    By skeetee in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-31-2006, 02:41 PM
  5. Ford Mondeo Estate Ghia X
    By HowieDee in forum Car Audio
    Last Post: 01-26-2006, 05:44 PM
