Page 7 of 11 FirstFirst 1234567891011 LastLast
Results 61 to 70 of 105
Thread: Carputer on a Budget: 2002 WRX ver. 2.0
  1. #61
    Constant Bitrate SnowDrift's Avatar
    Nov 2006
    MA
    ...but I think this will bother me. The hvac controls push up on the screen, causing this wrinke in the finish. Of this whole carputer project, the one thing I don't want to have to redo, tweak, modify, upgrade(unless for a bigger screen), etc,...is the bezel. And it looks like I may have to, even after all the work I've put in to make it perfect. If I have to redo it, I may just shave off or cut off the bottom of the screen's case. I really didn't think lack of room would be that much of a problem. I guess that's what I get for only doing about a month's worth of research. No wonder everyone else either uses the bolt-in kit or the in-dash sliding screen.
  2. #62
    Nov 2006
    MA
    Here's a better wrinkle shot.
  3. #63
    Nov 2006
    MA
    My desktop. The picture is a bitmap and the stars kinda "twinkle."
  4. #64
    Nov 2006
    MA
    And running RR with whatever skin. I like the look of it except for the blank square in the middle. HOPEFULLY I'll have time to make my own later on, but that's what I like about RR, all the choices, man.
  5. #65
    Nov 2006
    MA
    In between drying times during the week, I've been able to get other stuff besides the bezel done.
    I got a non-working emachine computer that was stripped of all useful components from work. I'm still trying to test it out to see if mobo or processor is salvagable. This could be the next carputer.
  6. #66
    Nov 2006
    MA
    But for now, I took the power button, hd and power leds from it to try to figure out how to relocate the power button on my dell.
    I took them, combined with parts I already had and half a spool of rainbow wire from radioshack, and ended up with...
  7. #67
    Nov 2006
    MA
    ...this. Nothing fancy for right now. I'm still look for a nicer button, and in the finished version, the led will probably be white or blue. I didn't use the power led because I figured I wouldn't need it. I used around 10' of wire because I'm not sure where it will be finally mounted.
  8. #68
    Nov 2006
    MA
    This close up shows how only 3 of the 4 pins were in a row. I had to repin my little harness. The button is a simple momentary on push button. Push once, computer turns on; push again, computer turns off. I couldn't firgure out if the dell has a reset button feature. I think any regular atx mobo would be much easier to work on than a dell.
  9. #69
    Nov 2006
    MA
    I also rewired the switch from my inverter. I just removed the original rocker switch, took the power cord from a broken power adapter, and bought a connector that fits the power adapter from radio shack. Now I can disconnect the wires to make it easier to mount the switch wherever I finally decide to do so.
  10. #70
    Nov 2006
    MA
    I also decided where I was going to mount the distribution blocks and inverter. I ended up chosing the "umbrella cubby." Here's mine with an "emergency" umbrella I've never had to use. I can put this cubby to better use.
  1. CARPUTER 2002 Accord FINISHED!
    By aznblueeboi in forum Show off your project
    Last Post: 08-18-2005, 11:37 PM
  2. WRX carputer project (working...)
    By gleinz in forum General MP3Car Discussion
    Last Post: 06-24-2005, 12:32 PM
  3. 2002 1.8T Jetta Carputer NEWBIE!!
    By hockmastr8 in forum Newbie
    Last Post: 07-09-2004, 10:08 AM
  4. 2002 Alpine Class A RV Carputer in dash w/mounted 10.4 LCD
    By ProjectDinero in forum Show off your project
    Last Post: 06-14-2004, 09:37 AM
  5. Carputer on a $800 Budget
    By f250crewcab in forum Newbie
    Last Post: 06-02-2004, 06:27 PM
