Page 4 of 16 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 157
Thread: 2006 MazdaSpeed 6 Audio Test Lab
  1. #31
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Wow, Very nice setup.
    You gotta love those Tang Bangs.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  2. #32
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Quote Originally Posted by tolisn View Post
    Is the screen motorized?. How did you mount it?
    Nope. It would be cool, but I never got around to making it motorized. Plus I am not sure I could get it stable enought that it would always work. Every Headunit that I have seen motorized breaks eventually.
    The only time I ever flip the screen closed is in neighborhoods I am unsure of or if I am out shopping. Got to keep the sticky fingers away.
    Thanks! Ya before the Tang bangs I had some Aura's that sounded pretty good, but these just sound so natural without much EQing. Vocals just sound so natural and open with no harshness. YOu jsut have to be careful not to exceed their frequency reponse and power handling. They break up easily once you reach that point.
  3. #33
    Sep 2006
    Look at my new goody! This card, a faster carputer, and a few software programs will set me free from the Alpine PXA-H701...I hope.
    My goal is to go 100% carputer for source and sound processing.
    I posted a review of this card and once I get it installed and acutally use it I will add more to it. I can't wait!
  4. #34
    Sep 2006
    The whole fabricated screen mount is nothing but MDF wood. I used 1/2" and 1/4" wood and alot of sanding. There is a 1/4" piece of MDF wood that holds the two sides together. I used two screws to mount the whole assemble to the dash by screwing into the plastic vents through the 1/4" piece of wood on the bottom holding the sides together. It also fits very nicely and is somewhat pressure fitted into the dash. The climate control/radio display Is also just pressure fitted into the dash. It will only come out if I remove either the screen mount or the radio bezel. It really isn't that fancy. If I take some more pictures you will see its very simple.
  5. #35
    Oct 2005
    As a fellow 6 owner awesome job, very nice and clean.
    I'm currently redoing my interior also with a bunch of goodies. I do have a motorized screen in the map pocket using a linear actuator.
  6. #36
    Newbie JohnnyO's Avatar
    Oct 2006
    Thats a great sound card. I have the same one in my HTPC! Its too bad they don't make it in a half height PCI card.
    Keep up the good work. -J
    -John
    DubPuter Progress [:---------] 05%
    2004 Subaru Impreza WRX
    Intel 845GL 400MHz FSB Main Board
    Intel Celeron 1.8GHz Processor
    D Link 802.11G PCI Wireless Network Adaptor
    On order - Lilliput 7" Toutchscreen
  7. #37
    Sep 2006
    Quote Originally Posted by CubanAffection View Post
    Ya the Linear Actuator method will probably hold up better than a motor. Did you have to do any cutting though to get the in your map compartment? I didn't want to cut anything.
  8. #38
    Sep 2006
    Quote Originally Posted by JohnnyO View Post
    I am a little disappointed in the ouput voltage from the card. I am going to have to be really careful with noise. Have you used any other cards that you could comapre it to? Just curious.
  9. #39
    Oct 2005
    Yeah I had to cut a good amount out of the bottom and the hole for the actuator.
    Here's an old video of it: (need quicktime)
    http://eden.rutgers.edu/~rudyd/DSCN2814.MOV
    I've since re-built it so it closes all the way and sound from the actuator was decreased with dynamat.
  10. #40
    Oct 2006
    Quote Originally Posted by durwood View Post
    Well I was using a USB turtle beach card which was a peice! The output voltage however on my home setup is not a factor for I am using the cards optical output. I guess some nicely shielded RCA cables would probably work out?
    -John
  1. Replies: 5
    Last Post: 10-12-2006, 11:25 AM
  2. RC3 Sound QUality
    By justintime in forum Centrafuse
    Last Post: 09-23-2006, 10:17 PM
  3. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  4. Sound Quality?
    By nettech_gt in forum General MP3Car Discussion
    Last Post: 07-21-2005, 03:48 PM
  5. sound quality of wafer 7850 ?
    By krazy in forum General Hardware Discussion
    Last Post: 07-08-2002, 06:48 AM
