Page 9 of 16 FirstFirst 12345678910111213141516 LastLast
Results 81 to 90 of 157
Thread: 2006 MazdaSpeed 6 Audio Test Lab
  1. #81
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I'm not using the Allocator delay because it delays both pairs of speakers which is no good in the car. Good idea for delays of drivers in the same plane or enclosure and you are spaced evenly in the middle of your speakers, but no good for car use. You need something that delays each side seperately. The resolution on the Voxengo Delay is perfect and you can do each L and R seperately.
    Cool on your install. You'll have to let us know how it goes. I want to switch to all software processing this weekend. What card are you using?
  2. #82
    Constant Bitrate Felix509's Avatar
    Feb 2007
    Lafayette, LA
    I didn't look too close at the allocator But now i see it is for a stereo pair.... That would have made it pretty easy..
    I Will be using the Echo Audio LAYLA3G Audio Interface.. Really great specs if you have room. It has 8 channels outand Mic preamp for the WinMLS software, pretty much everything i need until a better solution is found.. Not cheap though..
    Laters
    Ours is the age that is proud of machines that think and suspicious of men who try to.
    ___________________________________
    Current SYSTEM
    AMD64X2 2.5
    Xenarc
    ZAPCO DSP-6
    ARCAUDIO SE Amps
    Rainbow Profi CS365 & Profi Vanadium 12"
  3. #83
    Sep 2006
    Oh ya I forgot you said that in your email. That's cool because you could RTA right in your car with that card since it has phantom power on the mic. You got the MVC ok right?
  4. #84
    Sep 2006
    I've been very busy lately, mainly with my audio part of my setup. I have been testing a few things for the carputer but no real advancements in that area except for integrating my factory volume knob control. I'll get into that a bit later. For now here is what I have been up to....new speakers! here is what I put in my door for midbass-a SEAS L18RNX.
    The only problem I was worried about since these are home drivers, is that the voicecoil is open for water or whatever else trys to fall in there.
  5. #85
    Sep 2006
    So I picked up some of these foam baffles from partsexpress to use as rain shields.
    I then chopped off what I didn't need from the back of the driver and the bottom so that the sound is not sealed in.
  6. #86
    Sep 2006
    So now it's time for them to go into the door.
    Here is my door with the panel removed. Note how mazda did somethign cool, there is a plastic composite panel that you can remove to access the interior of the door.
    Removing the window
    Name:  door window.JPG
    And finally a naked door
  7. #87
    Sep 2006
    Next up is the Raammat I bought from Rick. I don't get too crazy with it like some people. I usually only apply one layer and maybe beef up areas close to the speaker or in the center of large flat panels. I don't run alot of power to my speakers so I usually don't get too many vibrations, plus Mazda builds some pretty quiet doors on their own nowadays.
    Then right behind the speaker area in the door, I applied a small layer of Ensolite which I also got from Rick at Raammat. This will help to absorb waves from the rear of speaker. He suggests not using too much of this behind it because it could overdampen the speaker.
    Next a few spots on the interior door panel where it vibrates. Notice how mazda put this white felt stuff to help reduce vibratiosn. Kudos Mazda-I was going to apply the ensolite here too but this was a pleasant surprise. That white stuff was not there in my 2004 Mazda 6.
    Also of special note, Mazda also put a gasket around the edges of the door so it does not vibrate against the metal of the door. It's no wonder I wasn't in any hurry to deaden the door. Mazda did a good job in reducing it for me.
  8. #88
    Sep 2006
    And finally with the speakers mounted:
  9. #89
    Jun 2003
    Memphis - TN
    Nice work!
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  10. #90
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    sweet, your getting me anxious... another 3 weeks till i get to start work on mine, so where do you compete anyway?
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  1. Replies: 5
    Last Post: 10-12-2006, 11:25 AM
  2. RC3 Sound QUality
    By justintime in forum Centrafuse
    Last Post: 09-23-2006, 10:17 PM
  3. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  4. Sound Quality?
    By nettech_gt in forum General MP3Car Discussion
    Last Post: 07-21-2005, 03:48 PM
  5. sound quality of wafer 7850 ?
    By krazy in forum General Hardware Discussion
    Last Post: 07-08-2002, 06:48 AM
