Page 1 of 16 1234567891011 ... LastLast
Results 1 to 10 of 157
Thread: 2006 MazdaSpeed 6 Audio Test Lab
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Ok I am going ot post some pictures of my old install from my 04 Mazda 6 since It had some good and bad ideas. I made some changes and this year the install will be cleaner with some software changes and hardware changes. My install is never done even though I have had a working carputer for over 3 years now. So don't expect to see my worklog in the finished projects. Posts 11 and on are my current install.
    Updated 3/2/07 For the second generation carputer.
    Equipment (Current)
    1) New Carputer -Installed (May 08).
    -Gigabyte Socket AM2 Desktop board $20
    -AMD 1640LE 2Ghz $40
    -1GB Ram $40
    -M2-ATX $50
    -PCI Soundcard Prodigy Hifi 7.1 $125
    -250GB Seagate HD $100
    -Lite-on Slot Load USB DVD-RW Drive $100
    -Logitech PS2 mini keyboard $7
    -Liliput 7" 619 TS $300
    -BU-353 USB GPS $50
    -Keyspan Media Remote - (At some point I want to integrate my factory buttons from the radio to control the computer in addition to this either with the car2pc adapter or a homebrew method) $25
    Total Cost $767 in Hardware
    2nd Retired Carputer -Installed (2/28/07).
    -Intel D865GVHZ Socket 478 Desktop board $20
    -Pentium 4-M 1.8Ghz $25
    -512MB Ram $30
    -M2-ATX $50
    -BU-353 USB GPS $50
    Total Cost $832 in Hardware
    Old Computer No longer in use First Gen
    -EPIA M10000
    -Liliput 7" Touchscreen
    -M1-ATX PSU
    -256MB Ram
    -250G Seagate Hardrive - (Seagate drives are super quiet and reliable and 5-Year warranty.)
    -Lite-on USB DVD-RW slim slot load
    -Creative Sound Blaster Live 24bit USB - (Temporary)
    -Dream works Mini-key
    -Keyspan Media Remote - (At some point I want to integrate my factory buttons from the radio to control the computer in addition to this)
    -Earthmate USB
    2) Software
    -Windows XP PRO (Not optimized yet) $130
    -Roadrunner (Deteremining donation ammount)
    -Digital Graphite Skin/Simplistque Skin
    -IGuidance 3.0 $100
    -Winamp
    -Frequency Allocator $100
    -Nero (came with Drive)
    Total Software $330
    New Software Under test (Software Audio Processing for tuning purposes
    -Frequency Allocator (Full version) $100
    -Console $50
    Name:  audio setup.JPG
    3) Electronics
    -2x Cerwin Vega EXL350.2
    -2x Cerwin Vega EXL400.4
    -1x Cerwin Vega XL600.1
    4) Speakers
    -4x 0.75" MBQuart RTC19 tweeter
    -10x generic 2" wideband midrange
    -2x 10" Tang Band WT-1427
    -1x 10" JL audio 10W6V2
    5) Audio Power
    0.75" mqquart tweets-> 2 channels 200Wx2 Cerwin Vega 400.4
    2" midrange -> 2 channels 200Wx2 Cerwin Vega 400.4
    10" midbass -> 4 channels bridged to 2 channels 350Wx2 dual Cerwin Vega 350.2's
    10" sub -> 1 channel 600Wx1 Cerwin Vega XL600.1 class H for efficiency.
    1500Wrms on the front
    600Wrms for the sub.
    My old install (Posts 2-5)
    I used to have these 3 processors to do what my Alpine can do now.
    -Audiocontrol Matrix 6 Channel Line driver
    -Audiocontrol Master Volume control
    -Precision Power FRX-456 Crossover
    Equipment no longer used
    -Alpine PXA-H701 (Time correction, crossovers, EQ, Volume control)
    -A/D/S PH15 6 Channel 50Wx6 (3 way front stage)
    -A/D/S PQ20 70Wx4
    -1" Silk Dome LPG25NFA
    -3" HiVi A3N 3" midrange
    -7" Scanspeak Revelator 18S/8531G
    -10" JL Audio 10W6V2 Subwoofer
    I have a hardware/software solution to replace the Alpine PXA-H701 Processor. I am almost ready to phase out the alpine and go 100% carputer including processing.
    Software options for Tuning
    Mounting Locations
    My screen is mounted in the original Map compartment
    The computer is mounted to the cross structure of the rear suspension except the hard drive.
    The Sub is mounted in the far rear of trunk on the passenger side
    The amps are mounted in front of the cross structure suspension bracing.
    The Remote is mounted on the retracted door covering the cupholders in the center console.
    TO DO List
    -Better volume control
    -Factory stereo dash controls and steering controls integration
    Projects Underway
    -Wire cleanup
    Finished Projects
    -Upgraded Earthmate USB GPS mouse to the BU-353
    -New Computer installed
    -Found a software / hardware soultion for sound processing
    -Molded Remote into cupholder cover
    -New Screen mount fits better, front cover molded into screen bezel.
    -Built a cover panel for processor/sub box
    -Made new Tweeter pods and made them look more factory.
    -Added sound dampening to front doors and rear parcel shelf.
    The order of this may change depending on needs.
    More to come....
    Sep 2006
    Here was my old setup. The changes were the midrange drivers were Aura 3", the sub amp was a Soundstream Ref300SX. I was using the old processors which have been replaced by the Alpine PXA-H701.
    Attached Files Attached Files
    Sep 2006
    Here are pictures of my old install...
    The screen pretty much the same as now. I can manually fold it down to hide it or just adjust it to reduce glare since I don't have a transreflective screen. I don't like motorized things because they are too tempermental. It locks into place by powerfull magnets when open.
    Sep 2006
    Old computer location in the center console arm rest...
    Great except the only problem was cooling. I had to add some extra fans later on because it got kind of warm and I didn't want the computer to fail. You can't see it from the pics but I had a 5.25" DVD drive mounted on top of the center console. I made a new housing/cover for the arm rest out of MDF and wrapped it in matching vinyl which covered the DVD drive.
    I removed the arm rest storage pocket by simply removing the screws from underneath the center console outer shell. It gave me exactly enough room for the homemade MDF computer case.
    Sep 2006
    Amplifier setup
    This was along the drivers side of the trunk. On the other side I had my sub and processors. The best part was that I still had a ton of trunk space and could fold my seats down. I also still had access to my spair tire. Too bad I can't locate better pictures
    Sep 2005
    A nice clean install. Some good looking ideas, good work man!
    Process meter!
    CarPC [#######-] 90% (In, some loose ends)
    Audio [#######--] 80% (Rear speakers to be installed)
    Total in car [#######_-] 85% (mostly everything)
    Feb 2006
    Virginia Beach, Va
    i cant wait to see more pics, hopefully i can get some ideas from this
    Sep 2006
    Thanks. I don't really have any more pictures of my old install. I will take pictures of my current install this weekend if its nice out.
    May 2005
    Nice install man, I'm glad to see I wasn't just being paranoid about mounting my comp in the center console. I couldn't see how I was going to keep it cool. I have the wagon so I ended up mounting it in behind the stock trim panels on the left side. I like your screen solution, I've spent over a year on and off dicking around with motorization and I'm about done. Even the units with pro R and D seems finicky.
    _
    Mar 2004
    Little Elm, Texas
    subscribed!
    I'm very interested to see how this install turns out!
    Jan Bennett
  1. Replies: 5
    Last Post: 10-12-2006, 11:25 AM
  2. RC3 Sound QUality
    By justintime in forum Centrafuse
    Last Post: 09-23-2006, 10:17 PM
  3. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  4. Sound Quality?
    By nettech_gt in forum General MP3Car Discussion
    Last Post: 07-21-2005, 03:48 PM
  5. sound quality of wafer 7850 ?
    By krazy in forum General Hardware Discussion
    Last Post: 07-08-2002, 06:48 AM
