Results 1 to 5 of 5
Thread: mkiv vw gti lilliput 2000 worklog
    Oct 2006
    OKay just got my lilliput so it's time to get to work! Too bad I have to wait to mid december (at the earliest) to get my opus 250w, <<any suggestions?
    I saw a few bezel's for the mkiv, but quite frankly I just wanted to dig in and mount this lilli up. I could see it was a centimeter or so larger than my din compartment, so I went out and bought a dremel and sanded the **** out of the console until it could more appropriatly accomodate my screen. The screen comes so gosh darn close to fitting with little modification, I decided to work around instead of using a bezel. Going to stick with stock trim on this one.
    After I ripped out the hvac console i bought a dremel and like I said sanded the inside edges, the screen jams in perfectly, I didnt want to take my lilliput apart because I want to keep the buttons on the screen so i can switch video inputs and also control screen brightness.
    Sanding the trim was hard as all hell, becuase that needs to be grinded down so i can stick em back on and let the screen recess,
    let me know what you think, I dont think i will ever be able to get the hvac unit back in lol.
    Oct 2006
    how do i delete a post in edit?
    Low Bitrate PSYKO_Inc's Avatar
    Oct 2006
    Fairfield, CA
    I don't think you can delete a post on your own. Just PM one of the moderators and give them the URL for the thread and ask them to delete or merge it. The work looks good so far from what I can see. You ended up with like six pictures of the dremel box tho lol.
    -Jay
    1997 Chevy S-10, ext. cab
    CarPC Progress: 75% - Functional, but not quite finished.
    Check out my progress.
    Newbie D4niel's Avatar
    Aug 2006
    Essex
    You need to remove the / out of the start of the line of code to display pics so each line of code looks like this:
    '[img]<insert web address for pic>[/img]'
    Oct 2006
    I think I want to use an AudioControl dqxs sound processor with my 3 amplifiers, computer, and mp3 player
  1. Display Info - 2000 VW Passat
    By jrdwiz in forum Newbie
    Last Post: 05-02-2007, 09:57 PM
  2. Replies: 0
    Last Post: 10-11-2005, 04:53 PM
  3. FS: 99.5 (same as 2000) VW Jetta GL 2.0
    By sniz55 in forum Classified Archive
    Last Post: 02-14-2005, 05:31 PM
  4. 2003 VW GTI 1.8T 20th Anniversary
    By askthefool in forum Show off your project
    Last Post: 10-26-2004, 10:21 AM
  5. Lilliput LCD, 2000 Celica GT and voltage problem
    By Goose in forum LCD/Display
    Last Post: 12-29-2003, 05:53 PM
