Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 54
Thread: 1999 Chevy Corvette Convertable V02
  1. #21
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    the new butler's are a new design (without balanced xlr inputs) so it would be a big undertaking to mod them. I think i am happy with my latest design though. It doesn't photograph all that well, but in person i like it. I'll take some pictures anyways.
    as for the attenuator. the pot has no interaction with the actual audio path, it is just used in the digital domain to control the attenuator board remotely. The thing you are looking at will work but will limit you to having to go back to the amp or soundcard to attenuate the volume of the sub. The joshua tree; on the other hand, would allow you to remotely adjust the attenuation from your dash
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  2. #22
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by PhilMayfield View Post
    I was thinking, looking at the design of the amps, it would look pretty cool if you had some frosted plexiglass covers made. Not to cover the whole thing, but with a cut out in the center for that middle portion to poke through. Maybe frosted... Think like an iceberg. I may just be nuts
    that would look cool too, but it's just a bit too 'flashy' for my tastes. If i had the room to cover the whole amp i bet frosted with portions (maybe a design of some sort) that was left clear would look pretty trick though
    M10k
    My Car Pc Install
    My Boat Pc worklog
  3. #23
    Dec 2004
    Los Angeles Ca
    I finally have everything that i need (componentwise) and they do look nice:
    This is my first fully active system and i'm pretty excited!
    now onto the install and tune
    M10k
    My Car Pc Install
    My Boat Pc worklog
  4. #24
    Constant Bitrate 00christian00's Avatar
    Apr 2005
    Italy,Ancona
    Hi Scott,really awesome setup,I also have the phaze and they are the best for my tastes!
    Some questions :
    -do you run the zapco with balanced input?How did you connect it?
    Do you have the scheme of the symbilink cable and made an adapter?
    -How do you run everything in active if the dac is only 2 channels?Do you have more than one dac?
    Download our catalogue here :
    http://www.noboringstuff.com/catalogoweb.zip
  5. #25
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by 00christian00 View Post
    Some questions :
    hey christian,
    thanks for the compliment, to answer your questions:
    yes i will run the zapco with balanced inputs.
    the phaze pin configuration is as follows:
    Pin 1 = ground
    Pin 2 = + phase
    Pin 3 = - phase
    the zapco symblink wire config is:
    L+ white
    L- yellow
    R+ red
    R- black
    +15v blue
    -15v green
    basically i just made a cable that has two xlr's connected to a symblink cable. not that hard to do
    i have the pin out at home if you don't have a symblink cable to hack up.
    as far as running everything active, i have a phaze ldx-23 active x-over. this is the layout (digital from the mobo to the dac, then balanced after that)
    mobo > dac > attenuator > x-over > amps
    M10k
    My Car Pc Install
    My Boat Pc worklog
  6. #26
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    That WILL sound good!
    Fine combination of good parts AND a well thought through design (signal-wise).
    Wouldn't it be an idea to control the attenuator with the PC? Just get an analog-out phidget/velleman board on USB and you're set. You could even combine with a potmeter so you can overrule the PC if needed...
    What about an xtronic case for the pc? The design is different but could look nice next to the amps....maybe
  7. #27
    Apr 2005
    Italy,Ancona
    So if i understand well,you basically connect xlr 1 to L+ and L- xlr 2 to R+andR- and where do you take the ground?shorting blue and green?
    I don't think the xtronic case will fit the phaze.
    What if you hide the lower part of the td1500,with the wood that cover from the middle of the amp,leaving the whole silver surface visible and with a design that isn't too much flat,but have the connectors and cables hidden.Then you can put the crossover completely shown,above this surface and between the 2 phaze,with the balanced cable that go under the wood,having some sort of central unit controlling them.You can then put some blue light inside the phaze and have some cool effect,you can even replace the light behind the tube.I think it will look nice.
    Below the xover,you place the zapco with the cover in par in the wood,max 1-2 mm outside,that seem like a sign.
  8. #28
    Oct 2005
    Hou. TX
    Quote Originally Posted by scott_fx View Post
    It shouldn't be hard at all. I'm just talking about modding the top cover from one of the new amps, assuming they will sell just the cover.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  9. #29
    Oct 2005
    Hou. TX
    The digital signal goes from the PC to the DAC which converts it to 2 channel analog. Then the anolog signal is divided up by the x-over. Each x-over output is balanced analog.
    All active means he does not have any passive x-overs in the signal chain.
    CarPC's in F-bodies
  10. #30
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Quote Originally Posted by durwood View Post
    Go job ont he setup, I thought I was the only one who went back and forth on how I wanted it to look. At least your equipment matches unlike mine. I'll be checking out your progress.
    And now why do you think my equipment is sitting in my room for almost a year?
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
  1. 1999 c5 corvette conv.
    By scott_fx in forum Show off your project
    Last Post: 08-28-2008, 06:46 AM
  2. 1999 Corvette torque specs
    By Cujo67 in forum Off Topic
    Last Post: 11-10-2006, 05:49 PM
  3. 1999 Chevy Lumina 3.1 Starter Problems
    By Duo Maxwell in forum Newbie
    Last Post: 12-25-2005, 12:11 PM
