Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 54
Thread: 1999 Chevy Corvette Convertable V02
  1. #41
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    the etched window may be a nice touch.
    the tc-9 is a larger sub then the id12 so it won't play nicely. i'm actually farming that part of the build out to an installer from the corvette forum. I refer a lot of business to him so he's making me a custom box for a reasonable price.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  2. #42
    Dec 2004
    Los Angeles Ca
    so I built the frames for the 'tool boxes' today. these will be lined with foam that has been cut out to hold some common tools. on top of that will be removable false floor panels. the subbox isn't done yet but i have a 'proxy' sub in there right now just for design purposes. The sub is inverted in the picture but the real sub will be facing the correct way with a rectangular grill protecting it and hiding it. the grill will have curved corners and be covered with grill cloth.
    I also decided to box off the back area. This will give the computer and amp some more airspace and allow the area to be a bit cooler. on each facade there will be a hole cut out for vent fans.
    the panels were tossed in there for pictures sake. i still have to build the supports for the piece and file some edges so the tie together a bit better... but you'll get the idea. (and the wires will all be hidden :blush: )
    onto the pictures:
    to do list:
    • sub box
    • mount zapco amp... 1/2 done
    • make custom xlr-symblink cable
    • wire up trunk
    • add fans for zapco amp and computer
    • make custom sub grill
    • carpet vinyl
    • add 2 more layers of deadening and a layer of ensolite to each door
    • install/aim woofers and tweets
    • complete custom pc interface (debating on doing this though)
    M10k
    My Car Pc Install
    My Boat Pc worklog
  3. #43
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    ...so jelous
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  4. #44
    Dec 2004
    Los Angeles Ca
    Got the car back today and the amp rack is done. I have to say the quality of work was outstanding. the amp rack was a lot better then the one i was originally making :leaving: I'm happy with 90% of the install but there are a couple issues that i have to bring up with them but i'm sure they'll be resolved (a couple were my fault :willy: )
    I made some good ground with the dash though, that is still my baby and You guys are going to see some things not usually done in a typical install.
    here are the pics so far, no night picks yet but it looks pretty cool. I swapped out the fan for a blue led fan and the tubes glow orange...great combo imho.
    all buttoned up:
    car pc:
    http://onfinite.com/libraries/1209121/820.jpg
    tc sounds tc-9 subwoofer:
    raw components (two Phaze/butler td1500's pushing 75wpc @ 8 ohms):
    dac 122 s/n ratio, 192/24 bit, balanced outputs:
    active x-over:
    sub amp (zapco ref. 500wrms @ 2 ohms):
    that's it. oh yeah, the carpet looks a bit off in the pictures but it's very close in real life.
    I'll post some pictures of the dash piece as soon as possible... once quick question. what do you guys feel is a better look, recessed or flush mounted screen?
    M10k
    My Car Pc Install
    My Boat Pc worklog
  5. #45
    Variable Bitrate rijndael's Avatar
    Apr 2007
    on Earth
    i personaly like the recessed look. flush just doesnt look right to me.
    i think a recess of about 1/4" would be perfect
    Trouble deciding on car speakers? Clicky Clicky
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
    Carputer: Removed for tablet install
  6. #46
    Oct 2005
    Hou. TX
    Quote Originally Posted by scott_fx View Post
    Can you give an example of what you mean? I'm not sure what your refering to.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  7. #47
    Apr 2007
    on Earth
    he is asking what you like more....
    do you like the screen to be flush with the surface of the dash (flush), or have it inside the dash just a tad (recessed).
    FLUSH:
    RECESSED: http://www.garymkatz.com/TrimTechniq...antelpiece.htm <== this will explain it
    Subwoofer: removed
  8. #48
    Oct 2005
    Hou. TX
    But as you can see
    There are like 3 levels assuming it even looks like this anymore. Which one would it be flush with? I would need to see more, maybe some mock-ups or photoshops to see what he really means. He may have changed it all around, I don't know.
    CarPC's in F-bodies
  9. #49
    Apr 2007
    on Earth
    i have a feeling it would be flush with whatever level he puts it in (if he goes flush)
    If he decides to go recessed, it owuld be pushed-in just a tad on whatever level he put it in....
    its not that hard man...i remember a saying once said to me "K.I.S.S" meaning...Keep It Stupid Simple...you are thinking too hard
    Subwoofer: removed
  10. #50
    Dec 2004
    Los Angeles Ca
    i meant how it was:
    or like this kinda....:
    not that big but that flush
    also, here are some teasers of what the dash has instore for it:
    the cupholder is gone and the space nav will take the place of it.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. 1999 c5 corvette conv.
    By scott_fx in forum Show off your project
    Last Post: 08-28-2008, 07:46 AM
  2. 1999 Corvette torque specs
    By Cujo67 in forum Off Topic
    Last Post: 11-10-2006, 06:49 PM
  3. 1999 Chevy Lumina 3.1 Starter Problems
    By Duo Maxwell in forum Newbie
    Last Post: 12-25-2005, 01:11 PM
