Page 6 of 6 FirstFirst 123456
Results 51 to 54 of 54
Thread: 1999 Chevy Corvette Convertable V02
  1. #51
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Your trunk turned out nice. Did you want the grill over the speaker white? I would have stuck to gray or black. Just my preference.
    That is a tough one on the screen. Recessed might help with glare and doesn't draw as much attention but you went transreflective right? The flush looks a bit cleaner. Would your climate controls be flush then too? I think either way would look great.
  2. #52
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    thanks
    the grill over the speaker is actually aluminum but i'm going to make a frame that slips in side the opening (will sit flush with the top of the amp rack) and it will be covered in black grill cloth. I'll also make a matching piece for the top of the x-over
    my ac controls wont be flush, maybe i should just recess the screen at the same depth as the a/c controls
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #53
    Oct 2005
    Hou. TX
    Quote Originally Posted by scott_fx View Post
    Yes, if your going for a clean OEM look, then recessed is the way to go.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  4. #54
    Dec 2004
    Los Angeles Ca
    This isn't the final product, i have a few more go rounds with the spot putty and the sandpaper but this will give you a better idea of what is going in that spot:
    here is a wider shot, the a/c controls need to be lowered a bit and there are some sanding issues...but:
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. 1999 c5 corvette conv.
    By scott_fx in forum Show off your project
    Last Post: 08-28-2008, 07:46 AM
  2. 1999 Corvette torque specs
    By Cujo67 in forum Off Topic
    Last Post: 11-10-2006, 06:49 PM
  3. 1999 Chevy Lumina 3.1 Starter Problems
    By Duo Maxwell in forum Newbie
    Last Post: 12-25-2005, 01:11 PM
