Page 5 of 21 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 204
Thread: New CarPC - this one for tuning
  1. #41
    _
    Mar 2004
    Little Elm, Texas
    bah!
    I can't believe I wrote sound...I ment video....I really really don't know what I was thinking....
    I must have been on the phone while I was typing....
    wow - I can't believe that...lol
    Jan Bennett
  2. #42
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    red please stop supporting thread jacking...
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #43
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Sorry 'bout that.
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  4. #44
    _
    Mar 2004
    Little Elm, Texas
    hehehe
    sorry!
    Jan Bennett
  5. #45
    Sep 2005
    Bellevue, NE
    And one more, to finish the 'jack.
    It turned out to be a bad video card. With another card, or onboard video, the sound is fine.
    So, now I have my ultimate: a PCI sound card and a PCI-Ex video card, on the same mini-ITX board.
    The sound card is currently a SB X-Fi; in order to bring this back on topic, how is your project with the Auzentech coming? I might get one to experiment with as well.
    Dave
    Core Duo CarPC
    CarDomain page
  6. #46
    Maximum Bitrate CJ8501's Avatar
    Jul 2004
    Orland Park, IL
    looking at your board Red, is it compatible with the pentium d cpu your using? Looks like it isnt according to newegg
  7. #47
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Caelric View Post
    A bit slow for the past few weeks. However, we're starting on the upgrade for the audio this weekend. I'll be ordering the new computer for the car shortly.
    Jan Bennett
  8. #48
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by CJ8501 View Post
    sure is. Have been running on my desktop for some time now.
    Jan Bennett
  9. #49
    _
    Mar 2004
    Little Elm, Texas
    Ok - some new updates.
    I have purchased the new CarPC:
    • Case:
      I went with this case because of the fact that it has a dual pci riser card. Since I'm running the PCI sound card, I need this feature.
    • Motherboard:
      MB899 Motherboard. Reason for going with this mobo was that at the time, there were only 4 choices for a mini-itx mobo that can run a core duo processor. The Commell has a PCI express slot, which won't work with this card. The Krontron was the same as this one, only avaliable on new egg...it's just a rebranded board. And the AOpen board doesn't even have a PCI slot. This mobo also has an optical output, which is critical incase this doesn't work and so that I can easily make the switch between the 701 and all processing on the computer.
    • Processor:
      Core Duo 1.83 processor
    • Fan:
      Cooler Master fan
    • Memory:
      1 gig of DDR2 667 memory: Patriot DDR2 667 Ram
    • Hard Drive:
      Seagate Barracuda SATA 3, 320 GB drive
    • PSU:
      DSATX PSU since the 150 watt Opus that came in the case isn't powerful enough for this set-up.
      I'll be running many of the same modules as before.
    • GPS Reciever:
      For instance, the ET301 GPS reciever:
    • GPS Antenna:
      With this antenna:
    Jan Bennett
  10. #50
    _
    Mar 2004
    Little Elm, Texas
    As for the DSATX: I modified the brain stem so that it could be perminately mounted on the outside of the case and connected to the PSU so that I could see real time specs on the PSU:
    After pulling the wires out of their sockets on a 4 pin wire, I soldered the pins from the brain stem to the wire:
    The cables with the pins in place and the other side without the pins in place.
    And with the pins soldered back to the brain stem and heat shrink over it all. Each individual pin is wrapped in electrical tape to ensure no shorting.
    Jan Bennett
  1. MP3Car CarPC State of the Union 2006
    By SwapMeet in forum General MP3Car Discussion
    Last Post: 10-18-2006, 08:32 PM
  2. carpc with name brand monitor
    By fasteddie in forum Input Devices
    Last Post: 08-25-2006, 07:09 AM
  3. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 08:40 PM
  4. Replies: 33
    Last Post: 09-01-2005, 04:14 PM
  5. Loud noice when turning on CarPC
    By Andreas106rally in forum Car Audio
    Last Post: 11-03-2004, 11:27 AM
