Page 6 of 21 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 204
Thread: New CarPC - this one for tuning
  1. #51
    _
    Mar 2004
    Little Elm, Texas
    Now for the RCA sockets:
    Here's the 8 runs or so of Encore II RCA wire from Straight Wire.
    Encore II: Encore II utilizes the highest grade of foam insulation for astonishing midrange fidelity. Our most advanced Star-Quad design, Encore II outperforms all other cable designs in this price class and insures high compatibility with nearly all components. Discover the significant improvement a Level 3 cable can make with Encore II wired throughout your system. XLR (balanced termination available)
    Cut away the rubber surround and peeled back the protective sheething:
    With negative shield peeled back
    Center wires exposed:
    Center wires twisted together and the ground cable with a piece of heat shrink around it:
    The wires solderd to the appropriate pins on the RCA sockets:
    Before being heat shrunk:
    After heat shrink:
    Jan Bennett
  2. #52
    _
    Mar 2004
    Little Elm, Texas
    Wiring that will be used for speakers and RCAs:
    The Focal Be Tweeters are driven by the front two channels of the STEG 4|01 amplifier (75w/channel). Speaker wire length for these runs are around 15'. The crossover point for these are around 5,000 Hz.
    40' of TEF 4/18 – stranded
    The Focal 3w2 mid-range drivers are driven off of the rear channels of the STEG 4|01 amplifier (75w/channel). Speaker wire length for these runs are also around 15'. The crossover points for these speakers are around 4,000 Hz - 150Hz.
    TPR 2/14 – 40'
    The Focal 5" Be midranges are driven off of one STEG 2|02 amplifier (150w/channel). Speaker wire length of this bit is around 12'. The crossover point for these speakers are around 150 Hz to 50 Hz.
    TPR 4/14 or Quartet 30'
    The Focal 40KX 16" subwoofer is driven off of the other STEG 2|02 amplifier. The sub has dual 2 ohm coils, so we are running the amp bridged at around 1 ohm. This amp was modified by Duane at Orca to make it stable at a 1 ohm load. Speaker wire length is around 6'. The crossover point for this speaker is around 40 Hz and down. Sextet 8'
    Encore II Interconnects.
    Jan Bennett
  3. #53
    _
    Mar 2004
    Little Elm, Texas
    I'll try and get some pics of the Tsunami distribution we'll be using along with how I have everything mounted in the PC case.
    Jan Bennett
  4. #54
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    so jelous
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  5. #55
    _
    Mar 2004
    Little Elm, Texas
    btw - I just placed an order for 4 of the LM4562 OpAmps.
    Jan Bennett
  6. #56
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    You suck J/k I haven't even gotten to paly with the other 4 opamps yet. Once I try those I'm goign to look at that one too. Gladd to see you are finally making some progress too.
  7. #57
    _
    Mar 2004
    Little Elm, Texas
    I haven't even had a chance to test the Burr Browns yet...lol
    gotta get this build done by the end of February though...have 3 shows to go to in Feb. alone...South Padre Island, NOPI here in Dallas, and Daytona Beach in Florida.
    Jan Bennett
  8. #58
    Sep 2006
    Shows around here don't start until april I think. Hopefully I can be ready by may. I've never been to the Daytona Event. That's farther then I am willing to go right now. Well sounds like you guys have your work cutout for you. Goodluck!
  9. #59
    _
    Mar 2004
    Little Elm, Texas
    It's only what, 6-7 hours from Chicago to Cester, WV, right? Steel Valley regionals!!
    btw - I'll be competing in USACi, IASCA, and MECA this year. Maybe we'll run into each other eventually...somewhere...hehe
    Jan Bennett
  10. #60
    Aug 2005
    south GA
    Quote Originally Posted by RedGTiVR6 View Post
    cool daytona... i may actually see the setup.... when is the daytona show?
    spring break nationals?
    69 Mustang
    408 clevor AFD 2v heads - Viper T56
    Audio:RUX-C701, PXA-H701, MRV-F545, (2) MRD-M1005, SIR-SC-H1, DMHD1000, Dayton Audio: (2) RS180-4, (2) RS28F-4, (2) RSS265HO-44 DVC
  1. MP3Car CarPC State of the Union 2006
    By SwapMeet in forum General MP3Car Discussion
    Last Post: 10-18-2006, 09:32 PM
  2. carpc with name brand monitor
    By fasteddie in forum Input Devices
    Last Post: 08-25-2006, 08:09 AM
  3. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 09:40 PM
  4. Replies: 33
    Last Post: 09-01-2005, 05:14 PM
  5. Loud noice when turning on CarPC
    By Andreas106rally in forum Car Audio
    Last Post: 11-03-2004, 12:27 PM
