Results 11 to 20 of 24
Thread: VW Golf 3 GTI car pc introduction
  1. #11
    Constant Bitrate mwmcginn's Avatar
    Dec 2006
    St Louis
    But he is running a laptop, why would he be buying another power suppy like the M1? Anyway, I did use a Kensington auto/air adapter on mine (keeping it DC). I got it for almost nothing on ebay. You could probably use that for both the PC and and the PSX if you dont use them at the same time. Add a switch to transfer power between the two.
    Best of luck with the install!
    Mike M
    2006 Accord VP Sedan
    My worklog
    http://www.mp3car.com/vbulletin/work...-dads-car.html
  2. #12
    Nov 2006
    Poland
    mwmcginn i don't use laptop, just on the photo i plug laptop because at the moment i don't have power suppy
    RedGTiVR6 u are right, but i check my local stores and polish internet stores and nobody have dc-dc converters so i buy power inverter. I now person who have that power inverter and everything work fine.
    About starting everything, i think it will be after plug car key, and after then i can turn on carpc or radio. When i take out key everything is turn off. I now i will have to turn on manually pc, but for the moment i'm starting with all of that so i think in the future will be some upgrades
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    so every time you get out of your car you will just be pulling power from the PC and not shutting it down properly?
    I don't know how long your operating system is going to las.
    Jan Bennett
  4. #14
    Nov 2006
    Poland
    no i will have to hibernate it first, i'm thinking about some system that check if key is plug in (power on specific port) and if not connect pins for turn on/off pc (xp configure to hibernate after power button push) and shot down the pc with time delay.
  5. #15
    Nov 2006
    Poland
    At the moment i have all staff, but now time to put it in my car.
    PC is working on WinXP Pro Mini 2.1 PL and is fest (minimum 64MB of ram required)
    I will put some new info when i start mounting everything in the car.
  6. #16
    Apr 2007
    New Jersey
    what's going on? I have a 1996 Jetta and I was thinking of using the same location, but it seems to be too low to use it while driving.
  7. #17
    Nov 2006
    Poland
    i just end installation for today, i will put some photos in a few days
    at the moment i have all cables in my car, ups battery change 2 use with my pc, motherboard / hdd install in my car, i have already mount the monitor but i will have to work with it more
  8. #18
    Oct 2004
    azizi,
    I understand that you tried your Lilliput EBY701 with your laptop's VGA output first, and now you are using EPIA 10000 VGA output.
    Could you please check what was the resolution that worked the best for this monitor in both cases?
    Were there any problems getting proper screen size without loosing any parts of the picture?
    Nov 2006
    Poland
    i think i have 800x600 resolution
    on epia it's working fine and i don't remember to have any problems on other stuff
    tray to auto adjust screen on different windows eg. on windows scream one time everything was moved right and i can't adjust it good, but on road runner screen i tray auto adjusting and it works ok, event when a back to windows screan
  10. #20
    Variable Bitrate john05srt4's Avatar
    Oct 2006
    Florida
    Quote Originally Posted by RedGTiVR6 View Post
    yep i was worried to but i have been doing it for 6 months and never had to reload my OS. It boots right back up in 20 seconds everytime.
    10 acura TL tech
    10 BMW S1000RR
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 01:39 AM
  2. FAQ: Why not Home PC speakers for the car?
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 03-08-2010, 09:44 PM
  3. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  4. Ordered my car PC system...
    By Merzbow in forum Newbie
    Last Post: 09-26-2005, 11:54 PM
  5. PC car questions... please help.
    By euclide in forum Car Audio
    Last Post: 05-25-2004, 05:51 AM
