Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 61
Thread: 2002 Acura RSX Install - Pistolen08
  1. #31
    Variable Bitrate Pistolen08's Avatar
    May 2005
    Tampabay, Florida
    Quote Originally Posted by smoresrock View Post
    omg wtf is going on.. i barely signed up for this forum and wanna head in ur direction. i have a PWP 2005 Acura RSX Type-S and just thought of putting in a carputer. i am def. gonna check out wut u did and follow after ur lead.
    Hi, welcome to the forums!
    What is a PWP RSX? Is that like an import thing?
    I'm still trying to cross the hurdle of my broken lcd, but I just recieved a few parts (including a ATI remote wonder 2, and a Griffin Powermate) so I'm gonna work on adding those in the meantime. The computer aspect of my project is done.
    Here is my to-do list:
    • Fix LCD
    • Buy GPS (BU-353)
    • Buy Bluetooth Dongle
    • Buy new cell phone with bluetooth
    • Position backup camera
    • Buy auto startup/shutdown controller for laptop
    • Buy Female-Female VGA Adapter
    • Get WifiHopper to work on TinyXP
    • Fabricate an enclosure for the amp, laptop, and antennas
    • Fabricate in Griffin Powermate
    • Find a good place for USB hub
  2. #32
    Mar 2006
    what are you going to use as the auto startup/shutdown controller
  3. #33
    May 2005
    Tampabay, Florida
    Quote Originally Posted by racerboy0712 View Post
    I am going to build W3bMa5t3r's auto power on module for laptops.
    Here is the link:
    Laptop Auto Power-On / Turn-On Module
  4. #34
    Mar 2006
    what are you doing/using to power everything
  5. #35
    May 2005
    Tampabay, Florida
    I am using a 140 Watt power inverter to power the laptop, and I spliced the lilliput power cable into the front ACC socket. I tested everything, and the inverter isn't giving me any ground noise.
    I ordered a new controller board for my lilliput from motorcitytech, and it should arrive shortly (it was $95 with shipping). I am going to figure out how to get my usb peripherals plugged in today.
  6. #36
    May 2005
    Tampabay, Florida
    USB Peripherals:
    Four Port USB Hub - Front (Cabin):
    • Lilliput Touchscreen (In front headunit area)
    • Griffin Powermate (In driver's side door)
    • 2 Misc. Dash Molded USB Ports
    Four Port USB Hub - Rear (Trunk):
    • ATI Remote Wonder 2 (Mounted in trunk enclosure)
    • Bluetooth Adapter (Mounted in trunk enclosure)
    • GPS Reciever (Mounted in trunk enclosure
    • Linksys 802.11g Adapter (Mounted in trunk enclosure)
    Laptop USB Ports - Trunk:
    • Logitech Quickcam Pro 3000 - Backup Camera (Mounted in trunk)
    • External Hard Drive (In trunk enclosure)
    • Laptop Auto-Power on module (Mounted in trunk enclosure)
  7. #37
    May 2005
    Tampabay, Florida
    This isn't my car (notice it's auto), but I didn't have a good picture of the trunk. I wanted to make an enclosure for the laptop/amp/everything else, so this is a quick sketch of how it will look. I plan on making it out of mdf, and covering it with carpet similar to the car's interior. Once the screen is in place, this will be my next project.
  8. #38
    May 2005
    Tampabay, Florida
    I decided to reinstall the OS, since TinyXP was holding it back. There were many programs that would not run/install (WiFiHopper, ATI RW2 software, etc..) and I figure that I can make it similar in run speeds by disabling services/using minlogon/etc... Luckily, I had 2 partitions (C: = windows, E: = everything else) so it shouldn't take too long, since I don't need to reinstall some of the programs.
  9. #39
    Mar 2006
    since you powered your laptop through an inverter...how do you turn on your laptop
  10. #40
    May 2005
    Tampabay, Florida
    I am in the process of building W3bma5t3r's Auto Power on circuit, as shown in This thread.
  1. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
  2. Anyone install LCD in Acura Vigor?
    By NorthGaVigor in forum Car Audio
    Last Post: 06-08-2004, 01:24 AM
  3. Install in a 99 Acura TL
    By codelogic in forum Show off your project
    Last Post: 04-12-2004, 04:39 PM
  4. Acura TSX w/ Nav - Computer Install
    By Spongebob in forum Show off your project
    Last Post: 03-16-2004, 12:35 AM
  5. RSX custom LCD Install
    By lopan in forum LCD/Display
    Last Post: 02-18-2004, 05:38 PM
