Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: 2007 Ford Falcon XR6 Turbo UTE
  1. #21
    Constant Bitrate long.1's Avatar
    Jul 2006
    Melbourne, Australia
    Hey djmickyg,
    I see you've updated the top of the worklog with some more progress photos earlier this month - good stuff. Looks like that custom install behind the seats is really coming along. Keen to hear more about what's going in each spot, etc.
    Cheers,
    Long.1
  2. #22
    FLAC djmickyg's Avatar
    Feb 2004
    thanks for the comments
    I have had a little bit og progress the past few weeks.
    atm the moment im doing all the re/wiring, tring to make that all look neat, (although im never happy with my wire)
    The 3 spots will have the pc in one, a small 8" Rockford Fosgate sub in one box from the old car and the middle box has the amp on one side and all the mess of wires and fuses etc on the other side..
    next is to make a cover for all the top so i can put all my rubbish back in it..
  3. #23
    Feb 2006
    To be honest, I saw Micky's setup a couple weeks ago at the Dyno-day, and it is looking sweet!
    Keep up the good work, with those custom enclosures no one will even guess what you have in the UTE
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  4. #24
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    djmickyg,
    How did you make the enclosures? did you use fleece to make them? I ususally use a chopstrand matt and it never comes out as nice as what you have done for your enclosures.
  5. #25
    Feb 2004
    Quote Originally Posted by mrbean_phillip View Post
    thaars the goal, if no one knows its there, no ones going ask to see my bad wiring
    Quote Originally Posted by meddler
    na i didnt use fleece, the the base of the boxes i moulded directly in the car, (covered with masking tape), and the flat sides I made seperatly on a flat waxed surface and once dry, i glued it all together with a Resin+talc power mix to make a thick glue and then trimmed off all the excess.
    Ive coloured the resin with a black pigmint cus i dont like the look of the blue/green finish normally and i didnt want to spray the insides of the boxes.
    I've also used a chop straned max.
    hope that alll makes sence.
  6. #26
    Aug 2002
    so it's just resin?
    btw, the install looks really clean. Nice work
  7. #27
    Feb 2004
    yep just coloured resin.. no magic tricks here.
  8. #28
    Aug 2002
    cool. thanks.
  9. #29
    Feb 2004
    small update.
    Done a little work to the car, new injectors, hi flow cat and a nice tune and I'm now making a healthy 302Kw at the wheel's, goes really good now.. was only aiming for ~270 but they managed to cram more from it.
  10. #30
    Aug 2002
    That's a pretty good dyno graph. 302kw for a ute will be fun in the wet and in the dry
    I had mine dyno'ed the other day. I thought 115KW at the wheels for a stock 2L turbo was pretty good.
  1. ELMscan Ford AU falcon (OZ)
    By odonus in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-24-2007, 08:14 AM
  2. New Car.. Forx XR6 Turbo
    By djmickyg in forum Show off your project
    Last Post: 04-23-2007, 08:06 AM
  3. Replies: 5
    Last Post: 01-06-2007, 06:17 AM
  4. Replies: 4
    Last Post: 06-16-2002, 04:26 AM
