Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 44
Thread: 2007 Ford Falcon XR6 Turbo UTE
  1. #31
    FLAC djmickyg's Avatar
    Feb 2004
    luckly the BF's have traction control.. witch now stugles with the 300kw's anyways
    still havent been able to give it heaps yet as its been raining for day's
    its still very drivable under ~2500 for when its wet.. cus u dont wana go above 3000 in the rain :S..
    they wieigh almost 1800kg's so its not a light car..
  2. #32
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    I have driven my mates BA fairmont and I thought the traction control was pretty crap. If the BF's are better then it might be ok. They weigh 1800kg?!? I thought they would be around 1400kg considering it's a ute.
  3. #33
    Feb 2006
    Melbourne, Australia
    Looking good, Micky
    Must be fun now in the wet weather we have in Melbourne - I can hardly drive mine
    But, still fun, enjoy it, and remember, with that power also comes a lot of responsibility.
    We should meet up sometime, and check each other's rides out....again...
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  4. #34
    Oct 2004
    Sydney, Australia
    2187nm of torque!?? wtf this reading must be bs, is there a "." in there? Love the fiberglass case. More work on the carputer and less on the engine!
    Continued Worklog... Upgrades in progress:
    *15.4" WXGA LED backlight touchscreen upgrade
    *Custom fiberglass dash bezel
  5. #35
    Feb 2004
    this is the torque after the diff
    the diff is a 1:3.45 so 2187/3.45 = ~600nm
  6. #36
    Mar 2007
    Quote Originally Posted by BiGGy View Post
    newtons NOT nm. related, but no direct comparison.
  7. #37
    Feb 2004
    Just an update on my screen.
    I've acquired this set up from a friend who sold his car, it was complete out of his car.
    But some cracks had started to form where he mounted the top screen,
    I started to fill up the cracks again but I figured it would just crack again..(just on the plastics, there is so ALOT of work that went into the back of it to make it all fit)
    So now i have decided to rip it all apart and plastic weld it all so i don't have to use any body filler
    Welded on strip of plastic and then below it's been sanded
    Much more to go
  8. #38
    Feb 2006
    @ Micky: What's the markings on your bezel? ABS or PPO?
  9. #39
    Feb 2004
    Quote Originally Posted by mrbean_phillip View Post
    Hi Phil.
    I couldn't find any marking's on the factory bezel, it may have been chopped out by the previous owner?, the plastic I'm welding it with is ABS and it adhering to it fine.
    why you ask?
    EDIT: I just went to check another bezel I have lying around and that says <PP0>
  10. #40
    Feb 2004
    a few more updates..
    the final sanding is taking ages. I have to keep felling up low spots and then sanding more.. but it's getting there..
  1. ELMscan Ford AU falcon (OZ)
    By odonus in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-24-2007, 07:14 AM
  2. New Car.. Forx XR6 Turbo
    By djmickyg in forum Show off your project
    Last Post: 04-23-2007, 07:06 AM
  3. Replies: 5
    Last Post: 01-06-2007, 05:17 AM
  4. Replies: 4
    Last Post: 06-16-2002, 03:26 AM
