Page 18 of 21 FirstFirst ... 89101112131415161718192021 LastLast
Results 171 to 180 of 206
Thread: Ford F6 Tornado Project Log
  1. #171
    Oct 2008
    Pa
    Nice install, and very nice ride.
    Its very clean and tastfull.
    Keep up the great work!
  2. #172
    cnx
    cnx is offline
    Nov 2008
    Sydney Australia
    Hi mrbean
    Look like you were right replaced the M2-ATX power supply with the M4-ATX 250w and I got the same
    Flickering problem like you said something to do with the ground. Do you have any more ideas on how to fix it?
  3. #173
    Feb 2006
    Melbourne, Australia
    Mmm....you could potentially tie the pc earth (negative) down to an (vehicle) earthpoint close to the carputer - this might rid you of the problem.
    I am finalizing my carputer enclosure for the Commell LS-372 board, and will get it in in the next few weeks - will then do some tests to determine what will work best.
    We may even need some pretty decent filtering caps on the psu-inputs to the pc and LCD, especially the lcd - and as close to the lcd as possible.
    Luv your ICC, looking neat - and with the Core-2-Duo logo, no mistaking for what's driving it. Did you get the overlay controls working, i.e if you adjust fan-blower etc, it should come ontop of your Centrafuse display, and turn off after a few seconds....
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  4. #174
    cnx
    cnx is offline
    Nov 2008
    Sydney Australia
    Thanks mrbean
    I got a touch screen overlay from eBay $99!! Works like a dream
    and I'm using speedfan with the centafuse plugin cool stuff
  5. #175
    Feb 2006
    Erm...pretty good about the touch-screen overlay - but I also meant oif you got the factory video-overlay working.....
  6. #176
    cnx
    cnx is offline
    Nov 2008
    Sydney Australia
    I never had a problem with the factory video-overlay the only problem I had is the flickering factory screen. You said something about filtering caps on the psu-inputs
  7. #177
    Sep 2007
    Melbourne
    Hey Bean,
    Would be cool to see your work we should catch up sometime, maybe even go for a horn up Reefton
  8. #178
    cnx
    cnx is offline
    Nov 2008
    Sydney Australia
    Hi mrbean
    Can I get some more info adout the the caps and you said tie the pc to ground is that of the mainboard ground (black)or the case?
  9. #179
    Jun 2009
    Carputer in the Terri
    Bean - great build. CNX, getting an overlay soon. Can I ask a coupla questions? Is going the Commell LS-372 much better than a mini ITX mobo? Is there any out there that will do the right vido mode- Or I have to go the CGA card? Some mini ITX are 12v in, should I still go a dc-dc supply? And.... get the amplified Ford audio cable? Or can the pc gain it up enough? Thanks
    btw its mynameisplayer...dang typo
  10. #180
    cnx
    cnx is offline
    Nov 2008
    Sydney Australia
    Hi mynameisplaer
    I’m using a MSI Fuzzy GM965 mini-itx mainboad with a pcie slot an ATI arcade vga card from ozstick.com.au
    made a custom cable. Got a pcie riser card and pcie extension card from logicsupply.com.
    Jetway jc-101-b mini itx case M2-ATX 160W power supply
    Perfect fit it all under the seat
  1. Ford Galaxy Ghia - CarPC project
    By Needstorage in forum Show off your project
    Last Post: 04-10-2006, 07:54 AM
  2. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
  3. Project "Ford Windstar XP"
    By Vchat20 in forum Show off your project
    Last Post: 02-14-2005, 04:47 AM
  4. Request : Project Log
    By ST34LTH in forum Mp3car Forum Suggestions/Comments
    Last Post: 01-03-2005, 06:59 PM
  5. Replies: 11
    Last Post: 01-02-2005, 09:33 AM
