+ Reply to Thread
Page 1 of 21 1234567891011 ... LastLast
Results 1 to 10 of 205
Thread: Ford F6 Tornado Project Log
    Feb 2006
    Melbourne, Australia
    Hello Everyone,
    After arriving in Melbourne, from South Africa, I decided to pick up a UTE and do a few mods to it, wrt both the engine and the interior, fit a Carputer, etc.
    With Projects like these, I always like to set myself some goals - or, more precisely, what the end project should look like...be like...perform like....you get the drift....
    Goals:
    1) Most important is the factory look! The mod must/will not detract from original factory looks...
    2) Powerful system, doing multitasking without ANY hickups.
    3) Deadreckoning GPS system, using Gyro and GPS input.
    4) Capacity to play MP3's, DVD's
    5) Internet Wireless connectivity.
    6) Infrared (IR) control of computer
    7) On/Off activation either manually, or selectively ignition controlled
    8) OBD-II (onboard diagnostics) display and logging of variables.
    9) Quiet operation, minimizing powerdrain.
    10) High-quality Touchscreen - 5-wire resistive is the best.
    I decided on a Morex Cubid mini-itx case, Commell LV-677 board, M2-ATX PSU, Merom 1.86gig Core 2 Duo Laptop CPU, mini-pci wireless card, and Commell mini-pci GPS.
    Other items include Pioneer Slotload Multiburner, Seagate Momentum 7200rpm, Sata 2.5" drive, and 1gig Geil ram.
    Al these cards onboard would make for a small footprint, yet very powerful setup.
    Here are some progress pics, and don't be mistaken, even though it is an extremelly small rig, with the addition of a decent 8800-based gfx card, you will be able to play any game at max settings! Serias.
    I realize a 8800 will not fit in this little box, but other than that....wow....
    Here I am busy assembling....
    From the other side:
    and to give you an idea of the size, look at how big it is compared to my WinXP Embedded case lying next to it
    Here is a shot from the back....
    and one of the front.....
    one from each side.....
    and one from the top, showing how it fits together, and location of components.
    I will post some new pics later, showing how nicely I have tidied up the inside, cabling etc.
    I will re-design the slightly tacky perspex front, instead use 5mm aluminium plate, which I will brush. Should add that something extra to the look - even though it will be hiding in a custom console I am designing for the Bakkie.
    Using the special automotive dc-dc powersupply, the M2-ATX, I had problems with the board starting up everytime, and I studied the issue with the manufacturer, and they discovered a timing issue with one onboard smd capacitor, which had a 22nf value, and was supposed to have been 10nf to be compatible with the Commell LV-677 motherboard.
    They wanted me to ship the PSU to the USA, and would fix it, so I decided I will do it myself.
    In the follwing pic, you can see the tiny smd capacitor, just to the left of a standard case-screw - hehe - not for the faint hearted.....
    After firing up my small solder-iron, using additional lighting, and 1 minute later, we hadd the new cap fitted - see area in purple....mmm...looks like a robot had soldered it in place, so even if I am close to 40, my eyes are still good, and hands are not shaking to badly
    Here's the result....
    So, now the Commell board starts up everytime, and no niggly shutdown issues either - well worth the effort, only problem was I have a total of 199 of these little capacitors left, as I had to buy minimum 200, but it was only $11- Aud, so no problem.
    Let me know what you think....
    Feb 2006
    a Pic to show how small these mini-pci modules really are - here is my Commell WiFi card next to a USB stick.
    The Commell LV-677 has 2 onboard mini-pci slots, similar to what a Laptop has to accept, for example, a WiFi card.
    With that in mind, I ordered a MP-954 GPS module, and a MP-2501 WiFi from Commell, for this application. Here's a few pics to show how these fit, and the compact size of this setup.
    and it this one, you can see the WiFi antenna fitted to the Morid Cubid case, just enough space for it, and still allowing the lid to close proper.
    I still need to fit the socket for the GPS antenna to the case, similar to the one for the WiFi, just on the opposite side.
    A Few pics from the rear, without the WiFi antenna fitted, and with it fitted - looks rather nice, and ....well....small.
    Feb 2006
    a Few pics of the intended victim. These generally come stock with around 270flywheel Kw, if you want HP divide that by 0.7456, to make it 362. Torque on the flywheel is 550Nm, or divide by 1.356 to get FtLb, 406FtLb, which is rather healthy for a Turbo 4Liter inline six.
    Generally, on average, these F6's make around 230rwkw, so that would give 308HP on the threads.
    Look at the numbers a bit later on to show what I did to it though
    Here I am standing next to my UTE on the Dyno
    This is what came out of the engine bay
    This is what we had before....
    and here is a few shots showing the difference, see if you can spot them....
    Feb 2006
    See attached dyno-sheets. - please note that these graphs represent rear-wheel power figures, not on the flywheel The car-buffs will understand what I mean.
    I settled for a conservative 368rwkw, leaving room for a bit more if needed, I have a 2nd tune for around 381rwkw, but, it is not significant more. Will give me time to get to know the UTE a bit better before I go overboard with powerlevels.
    Runs a bit better than the stock F6 Grandma Grocery-getter, so I need to be wakeup around the handling side of things now, as, even though you can see very nice linear build of boost, and thus power, the torque is a phenomenal 530FtLb on the wheels - add 22% to that to get the flywheel numbers, and then convert to Nm, quite decent numbers.
    To convert 530 FtLb torque to Newton-meter, we must use 1.356x530=718Nm, and this is on the rear wheels. Add 22% to this, and we get 875Nm on the flywheel - which makes for a fun experience.
    Same with the horsepower, for 493hp on the wheels, we will have 602hp on the flywheel 368rwkw x 0.7456 = 493hp, + 22% = 602hp (flywheel)
    493 odd HP vs torque (FtLb)
    RWKW vs Boost Press
    and RWKW vs Lambda
    Feb 2006
    Lastly, a 11meg video clip to let you hear what a approx 600hp-on-the flywheel sounds like on the Dyno - screaming like a mad dog.
    Constant Bitrate MrJamieR's Avatar
    Jan 2007
    Melbourne, VIC
    Great start to your project. I'm nominating you for lucky bastard of the week. Great car (if you're a fan of Team Blue) and a nicely spec'd carputer. I liked the case you used but couldn't find a reference to "Morid Cubid" anywhere. Where do you find it? BTW is it a mini-ATX or mini-ITX case?
    Jan 2007
    Melbourne, VIC
    Just had another look at those dyno sheets. Make it lucky bastard of the month!
    FLAC djmickyg's Avatar
    Feb 2004
    Very nice car! fitted with the cobra kit.. I'm not even gonna ask how much this has all cost.
    Constant Bitrate long.1's Avatar
    Jul 2006
    G'day Beanie,
    Can't say your not dedicated or passionate about your vehicle. An impressive list of achievements indeed, and the carputer is just one of them. It will be quite different for me though, if and when my carpc goes ahead, it will most likely represent 100% of the car mods.
    Quote Originally Posted by mrbean_phillip View Post
    Hey Long.1,
    Which ICC you have? Probably prestige sound with color LCD?
    I find it may be significantly easier to mod the mono-LCD setup, especially wrt space for fitting a 7" screen.
    With a DualZone ICC, I would say max tft touchscreen that will fit would be 6"
    Regards,
    Beanie.
    Responding to your questions (above) raised in a separate thread, my car is a Ford Territory Ghia (shown here), so the "official" specs listed are:
    - The Premium ICC (with dual climate control, large colour screen and trip computer), and
    - Premium audio system (with colour screen & 6-disc in-dash CD, 150 watt amplifier & sub-woofer).
    So looking ahead a little, I'm naturally interested in your dash fabrication given our similar dash. At this stage I'm still heavily into project research, so I'm not too sure what components my CarPC might end up with. We'll see I guess.
    Good luck for the rest of your project, and no doubt future projects. I'll be a keen observer, and with any luck a contributor.
    Cheers,
    Long.1
    Feb 2006
    Heya Guys,
    Thanx for the feedback from everyone, it is appreciated
    I am indeed lucky to have such a nice toy to play with - very lucky, and I am grateful.
    @ Long.1: I have the std Manual MCC, you know the small single color LCD one.
    Well, today I have picked up some more hardware, to actually turn it into a full-blown Dual-Zone Climate Control like yours, I have the ICC already, with 6-stacker (although my Prestige sound have the same stacker) and I had to replace a damaged LCD panel on this ICC - cost me a healthy $640- Aud
    So, still need a wiring loom, and then Ford must reflash both the BEM, and HIM modules to correctly operate the new ICC.
    It's going to look 100% factory, as I will beusing the same TFT color LCD that the big unit comes with, I need to get a NTSC 15kHz composite VGA converter - std LCD panels use 30kHz as a sync.
    This specific Ford LCD's use arcade-type sync, so I should get something somewhere, or simply build a level converter.
    It would leave me with a decent 8", and 7" Xenarc TSV700 as spares, but that is ok.
    All I need to do is get a Touchpanel overlay for the Ford LCD, and I am set
    Will keep you posted, and waiting with baited breath on both yours and djmicky's setups.
    Best regards,
    Beanie.
+ Reply to Thread
  1. Ford Galaxy Ghia - CarPC project
    By Needstorage in forum Show off your project
    Last Post: 04-10-2006, 07:54 AM
  2. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
  3. Project "Ford Windstar XP"
    By Vchat20 in forum Show off your project
    Last Post: 02-14-2005, 04:47 AM
  4. Request : Project Log
    By ST34LTH in forum Mp3car Forum Suggestions/Comments
    Last Post: 01-03-2005, 06:59 PM
  5. Replies: 11
    Last Post: 01-02-2005, 09:33 AM
