Results 11 to 20 of 21
Thread: 2006 Tacoma, in dash "Tacoputer"
  1. #11
    Newbie DaveWilliamsTX's Avatar
    Feb 2007
    Denton, TX
    Well, I've got the mobo on standoffs, but those standoffs are expoxied onto the case (I scratched it up pretty good to give the epoxy something to grab on to. I'm going to put gorilla glue on over the epoxy just to be safe, but I'll probably still have to keep my eye on it to be sure it keeps hangin.
    Can't wait to get it in!
    It is no use saying, 'We are doing our best.' You have got to succeed in doing what is necessary.
    Winston Churchill
  2. #12
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I used metal standoffs in my build, Drilled and tapped some 6-32 holes in the chassis and screwed them in. I never thought about using epoxy for standoffs but thats a good idea. There is epoxy out there that is actually stronger then the metal it bonds! I have some at my work that is an industrial product called "Lord Adhesive"
    Can't wait to see it installed in your truck.
  3. #13
    Constant Bitrate diosagain's Avatar
    Feb 2007
    New Jersey
    Where did you find the "Rustoleum fine texture flat black spraypaint"? I too bought the black matt plastic bumper spray paint and based on what you wrote above, I don't think I am going to even bother popping the cap on it. I looked online for the rustolem one, but have had no luck.
  4. #14
    Variable Bitrate breaker021's Avatar
    Apr 2005
    Midtown Manhattan
    Nice progress - just be careful where you touch the tip of your magnetized screwdriver! they're great for working on cases but on motherboards or other electrical components, be careful!
    - sh00k
    Duct tape and a Bandana for the win, b!shes!!!
    My Setup:http://www.mp3car.com/vbulletin/show-off-your-project/73500-06-scion-xb-tablet-in-the-box.html
    Cost so far: Less than a grand ;]
    _________________
    Economy/Commuter cars + Computers = many entertained miles
  5. #15
    Feb 2007
    Denton, TX
    Quote Originally Posted by diosagain View Post
    I found it at Home Depot, its not an exact match to the stock black pieces in the interior, but its durable, looks good, and helps to hide the last of the small imperfections in my bezel. Its a spray paint that is made to get good adhesion on plastics, and I'm thinking that is what makes it feel so much more durable in this application.
    And, yea, you definitely don't want to get the magnet close to the HD, but for putting the LCD screen in with its tiny screws it was helpful. The nice part about that little set up was that after I took the magnet off, it left a residual magnetization on the tip that was just barely enough to hold a screw on.
    Thanks for the compliments, just waiting on an amp and shes going in the truck! (I wish the HQCT-eA was available on the website right now, two birds with one stone would be amazing)
    Winston Churchill
  6. #16
    Feb 2007
    New Jersey
    I wound up using the rustoleom and it came out good. You're right it doesn't really match the trim but its only slightly off. What do you think about spraying the trim spray using a light coat over the rustoleom spray. Here is the picture if you want to take a look:
    First Time Fab - 2003 Ford Explorer - Please help! - A lot of pictures...
  7. #17
    Feb 2007
    Denton, TX
    if its straight plastic, and you could lightly sand it, you could probably do it. I'm not that bold, though.
    Winston Churchill
  8. #18
    Jul 2005
    Motorcity
    Blog Entries
    1
    any updates dave?
  9. #19
    Feb 2007
    Denton, TX
    Glad you bumped this, I've been so busy with grad school that I forgot to update. I've had the tacoputer installed for a couple of months now, and it's been working like a charm.
    The install was not without a couple of hiccups, but for the most part the planning I did was enough to make things go pretty smoothly. I removed the driver's seat (easy to do, 4 bolts) so that It'd be easier to run wires and mount the amp under the seat. This turns out to be a great place to mount the amp, as there is a rubber grommet and grounding bolt directly under the driver's seat on the frame. With this ground, I've had no noise like I've had on some car audio installs.
    It was DEFINITELY a tight fit, however, and even with 90 degree plugs on the back of the mobo, I had to modify some of the in dash pieces to get it to fit, and its still pretty snug. There is a heavy plastic piece that runs behind the stock radio that I had to cut up to make room for the audio cables to run underneath the computer. If I had to do it again, I'd have gotten a smaller mobo.
    The .063 aluminum chassis that blk02si bent up for me needed to be modded, but has provided enough stability and support to hold all of the pieces sturdy, even on rough dirt roads.
    I'm using Iguidance and Streets and Trips for nav, depending on the situation - I love the expandability of the carputer - definitely the biggest plus.
    A big thanks to the forums for all the info, could not have done it with out you all. Anyone with any questions whatsoever, please post them here or PM me, I'd be glad to lend a hand.
    Winston Churchill
  10. #20
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Where are the pictures?
    Rafster
  1. Help on custom dash for Caddy STS
    By Slaughterhouse in forum Fabrication
    Last Post: 12-14-2006, 07:47 PM
  2. 01 Dakota Dash
    By jpx7777 in forum Fabrication
    Last Post: 02-19-2006, 10:19 PM
  3. 2003 Altima Dash Fabrication
    By in4no in forum Fabrication
    Last Post: 02-11-2005, 11:51 AM
  4. Sanding dash, need help!
    By mazda3uzr in forum Fabrication
    Last Post: 12-22-2004, 06:27 PM
  5. In dash or Not in dash that is the question
    By belezeebub in forum Fabrication
    Last Post: 12-10-2004, 06:18 PM
