Carputer setup
I have been using a VoomPC case for my previous install. It was working well for me but I needed more space. So I found an old plastic case laying around the is perfect in size.
The case. The RCA plugs go to the HQCT radio tuner. I'm planning to use the HQCT as the audio input selector, volume and tone control. I have been writing a plugin foor Road Runner to do this and it works very well. This allows me to use the audio from my pda with TomTom navigator to be mixed with the audio signal from the carpc or the tuner. Above the RCA connectors are two USB ports.
The HQCT installed. Still need some tidying up of the cables. Test the setup but got some interference of the power supply when using the radio. I'm going to build a case around the HQCT using PCB material and place a filter on the powerlines. The HQCT was performing very well in my previous setup but it was then built into a seperate case.
A complete overlook of the case. As you can see; need to tidy up the cables...
LinkBack URL
About LinkBacks
