Results 11 to 20 of 21
Thread: cpc in volvo 440
  1. #11
    Feb 2007
    netherlands
    How to work:
    - find a place for your screen.
    - measure the area around the screen twice!!!
    - decide how you want your screen to move.
    - draw the hole area including the area needed for the moving screen.
    - leave margen so you can adjust the positions.
  2. #12
    Feb 2007
    netherlands
    How the screen moves:
    We can break this down in two parts:
    - mechanical
    - electric’s
    mechanical:
    - the engine powers a drive-belt, which rotates an axle. On that axle there are two aluminium L-brackets
    - the L brackets control the switches.
    - The movement of the second axle is transported via a belt to the top axle.
    - The top axle rotates the screen
    - magnets keep the screen in the closed or opened position.
    Electric’s:
    - needed:
    - 2 switches
    - 1 modified sailboat-servo
    - 1 relays
    On the relays you connect the + and – of a 5 volt line (i used m2)
    The relays has 2 outs on each connection!
    To the servo 4 wires will go from the serve.
    In the two + wires that go to the servo there is a switch.
    When the switch is pressed, the connection is broken and the servo stops moving.
    The relays is controlled by the + of the ignition key, but that can be every other switchable +.
    on the picture at the buttom the switches (black) with the magnets
    close-up of the relays and servo (tape is to reduce the force of the magnet, not to hold it in place)
  3. #13
    Feb 2008
    I would like to know what went in the manufacturing of the mechanism, and also how it's all put together....
  4. #14
    Feb 2007
    netherlands
    updated mecanical part, hope it answerd your question
  5. #15
    Feb 2007
    netherlands
    moved the cpc to the inside of the car, thought that would solve the cold weather problem i had. But it didn't.
    old instal under the seat:
    the old tray in the car:
    A new mobo was order, the dg45fc (intel) testing and install in progress.
  6. #16
    Newbie jadik's Avatar
    Oct 2008
    Lithuania, Klaipeda
    Quote Originally Posted by rijk View Post
    the screen arrea:
    I'm thinking of making smthng like this in my volvo 960, could you send me a .cad file?
  7. #17
    Feb 2007
    netherlands
    i can, but the drawing was made for the center consol of the 440, so i don't know if its any help to your project.
  8. #18
    Oct 2008
    Lithuania, Klaipeda
    NP, it's easier to make some adjustments than start from the scratch =]
    I'll PM you my email =]
  9. #19
    Feb 2007
    netherlands
    the tray is in the car:
    connecting up the mobo to the car:
    cover to protect the cpu fan and m4. black bit is speakercloth, so cooling is not reduced.
    The mobo hangs upside down under the seat.
  10. #20
    Feb 2007
    netherlands
    The first place of the mobo with the first casing (drilled), second casing was the closed one, but for the rest pretty mutch the same as this one. The closed version was to reduces the amount of airflow over the mobo. Can you imagin a mobo that gets to cold:
    Quote Originally Posted by HiJackZX1 View Post
    I remember looking through your work log.... How does the PC get ventilation? Is it connected to the fire wall? Also on my Porsche 944 I know it had a similar area were you whave yours and I always had issues with water collecting in there, how are you avoiding this?
    It was vented by the air that was sucked in by the interieur fan (blower)
    Pic 1) is the normal and the modify top of the air-inlet. You can see 4 bolts.
    Pic 2) is the backside of the air-inlet with the mobo attached (i was testing the space for the metal bar (black with the grove in it)
    Pic 3) the old air-intake. On the bottom you can just see the fan (blower)
    Pic 4) the mobo in the car bolted to the air-intake (it had a specific order in witch bolt / screw to tighten up) Putting the mobo in its place took about 30 minutes (some of the nuts where very difficult to reach.
    Pic 5) The water draining hole with the wiring
    On top of this sites the plastic cover, so all the air comes from the right side:
    Cpc was mounted under the black cover on the left
    close up cpc (changed the case to a closed type aluminium)
    The air-intake is lifted up about 3 cm. And there are two holes that drain the water away. Threw one of the holes i thread the wiring.
    The temp of the mobo is about the same as the outside air-temp. If i lived in a hotter country, or the global warming picks up this is still the space i think is the best for the mobo.
    I’ll post this too in the worklog, i got a feeling Red’s gone delete this post.
  1. 2005 Volvo S60 1,3 GHz 120 Kw
    By cala in forum Show off your project
    Last Post: 04-08-2010, 07:25 AM
  2. Volvo S60 in-dash project
    By JC-S60 in forum Fabrication
    Last Post: 02-16-2010, 04:10 PM
  3. ** Volvo C70 SC-805 Head Unit & AUX In **
    By billyb0b in forum General Hardware Discussion
    Last Post: 02-13-2007, 01:04 AM
  4. Volvo V40 2002
    By Rik in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-31-2006, 05:41 PM
  5. Volvo 240 Sedan Questions (Super newbie)
    By gtaubman in forum MacCar
    Last Post: 06-28-2005, 02:25 PM
