Hi Aeroanderz,
Only just found your reply on this thread.
In answer to your questions:
The Bezel for the screen was a modified (extensively) broken Saab OEM nav screen. I cut it back to accommodate the Lilli and then attached the bezel to the screen with superglue. The screen was mounted inside the bezel mounting frame supplied by mechatronics see link:
http://www.mechatroniks.com/wrx/lili629.html
Also in the mounting frame I installed the
Carnetix 2140 and a 7 way powered usb dock.
I'm currently trying to locate an old or broken 9-5
head unit, to get the 26pin connector to make the
wiring in of the amp easier.
If you could get hold of a similar unit you could modify the front face plate to use as a screen bezel.
Let me know how you get on.
Regards
Colin
