Page 6 of 12 FirstFirst 123456789101112 LastLast
Results 51 to 60 of 112
Thread: 2007 Honda Civic Si Sedan
  1. #51
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    works great if you're using a PC...
  2. #52
    Low Bitrate erie's Avatar
    May 2006
    USA
    Ya I heard that the s/w controls was just one wire, but I dont know where that wire it is. Even looking at yrean's wire harness there is not a s/w signal wire
    If its just voltage differences could you use 2k1Toasters "Fusion Brain" to read the voltages http://www.mp3car.com/vbulletin/hard...ion-brain.html
    BTW Nice install, looks like you've spent a small amount of gold for the eclipse equipment. Cant wait to see it after your done. What plans do you have for the factory speakers? Did I miss how you control the mini? Is the eclipse a touch-screen?
    06 Galaxy Gray Si #0308
    CarPc Progress -
    10%---------50%---------100%
    -[XXXXXXXXXXXXXXXXXXXXXX]-
  3. #53
    Jun 2006
    Denver, CO
    well, i looked into the fusion brain, but again, for windows users only. the mini is not installed yet.
    As far as mac control: I had a griffin powermate to control it in the corolla, but the corolla didn't have steering wheel controls either. I don't want those to go to waste in the honda.
    There's some serious thought that has to be put in that i haven't yet to figure out how to set up the control set for both the mac and the eclipse, and also how to switch between the two command sets. I have some idea of how to do it, and i have a good diagram of all the components in question. I still have an extra VSA OFF switch which i may use to change command sets.
    I think i can pull this off pretty clean, but it's complex and the last thing i feel like doing is having my car in twelve pieces and then finding out something isn't working quite right.
  4. #54
    Variable Bitrate portabuddy's Avatar
    Feb 2006
    mississauga, On.
    i would have to agree, the install looks good thus far, and the controlls are a big issue, they are there and must get used, persaly i got another of everything, the little piece under the top cluster for my 2X16 display screen, the left dash the right dash, all so i wouldnt have the parts orn apart while painting it also if i chose to sell the car and the guy is a knobe i can piut it all back and sell the carputer to someone more deserving. im sure you'll pull off the controls for the mini and eclips, i dont know jack about mac's but let me know if i can help...
    Life Dosn't come with a reset button, if it did you might as well turn the game off.
  5. #55
    May 2004
    Denver
    the 50 to 60 hp bump will be more for a turbo in Denver... a stock Si at say 200hp makes about 24% less than that in Denver... so figure 152hp at the flywheel... but a turbo will spin faster due to the lower air density and will make up some of that lost air... figure about 15% losses... so a 260hp turbo'ed car will make about 221hp... so that will be a 50% power gain...
    not to mention the slightly lower boost than design, you'll make about 1psi less than the same setup at sea level... so the setup will be safer cause you are barely making 10% over the design setup...
    I make 15psi in my 2.0 wrx and with a free flowing cat turbo lag and spool are minimal issues - I make about 2X hp over stock at 2500rpm...!!! on a hot day with the A/C running it used to just fall flat on it's face below 2800rpm... not an issue since the exhaust upgrade... I went from a stock 226hp to about 285hp and the difference is night and day... 0-60 was 5.7sec, now it is closer to 4.5sec... will probably do the turbo swap this summer...
    anyway, things are coming along pretty smooth their "gohybrid"... I've been so distracted lately with other projects that the car has been neglected... built an arcade and am finishing that up over the next week or so - it is over the top...
    EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
  6. #56
    Constant Bitrate zapwizard's Avatar
    Aug 2002
    Austin, TX
    Quote Originally Posted by GoHybrid View Post
    I'm going to research some mini cameras now and see what I can come up with.
    as always, input is welcomed.
    here are some candidates:
    http://www.supercircuits.com/index.a...OD&ProdID=4143
    http://www.supercircuits.com/index.a...OD&ProdID=4237
    http://www.palmvid.com/content/categ...=live_demo#tab
    despite the cost of the last one... the imaging in the dark areas of the demo room is pretty freaking cool.
    I have a lot of experience with the cameras from SuperCircuits, they are great quality, their office and showroom is also 30 minutes from me I have been by and they are nice.
    The first two camera's there have a FOV of 70 degrees (Measured corner to corner) The 3-lux camera will not be able to see anything after sundown. The 1-lux won't be able to see at night without light assisting it.
    The 823 model camera costs a bit more, but is by far the best camera I have ever used. http://www.supercircuits.com/index.a...OD&ProdID=5684
    It has a 110 FOV rating, a 0.05 lux low light rating, and more lines of resolution. You can also get a pin-hole version which may make it easier to hide, weatherproof and clean.
    I have one of these as my rear view camera (still in the works) but I have install two of them at my neighbors house, and it can very well at night.
    If you want really good low light you can get a Sony HAD camera with a 0.003 LUX rating. I have one of these as my front door camera on my house, it comes in a weatherproof bulletcam case.. It also has a wide angle, but is black and white.
    Here are a few photos from that camera:
    http://www.flickr.com/photos/zapwizard/tags/camera/
  7. #57
    May 2004
    Denver
    I have the ebay camera, it was lieke $60... it is advertised as 110 deg FOV, but I measure it to be 65 degrees... but it is self illuminated... uses RCA for the video feed...
    keep in mind that no matter what setup you use, dirt will always be getting on the lens, so plan on having to wipe the lens at least every gas fill up... it would be slick if there was a way to mount it behind a window with a wiper...
  8. #58
    Feb 2006
    mississauga, On.
    umm question?, whats a vsa off switch and where is your mirror controle?, mine is in the cluster where you hace 3 buttons(the mac vsa and blank...) i need a fog light and a carputer switch, and posably a nother one for light of some other kink, so that 3 way bezzle would come in handy, can you post a pic of where your mirror switches are?
    this is what mine looks like...
  9. #59
    Feb 2006
    mississauga, On.
    NM i found it on the 3d view of the us model SI, its on the left hand window controle console.. that unfortunetly wont work cuz i have a handle in the way there... unless i can make it work, also those tro extra buttons on the steering wheel look handy, those could make for good function keys of some kind... Hmmm...
  10. #60
    Jun 2006
    Denver, CO
    One Step Forward, Three Steps Back...
    I was awakened by a knock on the door at my apartment at 3:30 this morning from a friendly Greenwood Village police officer who informed me that my car had been broken into.
    This is what followed:
    I have to say, i am just heartbroken. I just had an awful breakup with my girlfriend of two years, and this car, this project was my salvation...
    otherwise i could think of nothing but the pain of what happened between me and her.
    It's just a hobby i know, but i poured my soul into this. I took pride in it. Then someone in just a few short moments of selfish and cowardly behavior just destroys all my efforts.
    As I mentioned in another thread, the only real way to protect yourself is to insure everything... which i had done. So this will all get fixed... but it's just not something you can take to circuit city and get done right.
    Anyway, thanks to everyone for your input and comments on my project so far... i always appreciate when someone takes the time.
    The car and I will both get through this, hopefully sooner rather than later.
  1. Replies: 6
    Last Post: 03-18-2007, 11:51 AM
  2. Custom Dash with 700TSV for 02+ Honda Civic Si
    By xmadcowx in forum Classified Archive
    Last Post: 09-06-2005, 11:12 PM
  3. 1999 Honda Civic SI HondaPuter
    By Chris732 in forum Show off your project
    Last Post: 08-11-2005, 11:37 PM
  4. 2001 Honda Civic Sedan Carputer.
    By dannn in forum Show off your project
    Last Post: 08-10-2005, 07:17 PM
  5. 99 Honda Civic Sedan Screen Install
    By CustomZ02 in forum Fabrication
    Last Post: 10-07-2004, 10:13 PM
