Page 9 of 12 FirstFirst 123456789101112 LastLast
Results 81 to 90 of 112
Thread: 2007 Honda Civic Si Sedan
  1. #81
    Variable Bitrate portabuddy's Avatar
    Feb 2006
    mississauga, On.
    do you happen to have a pinout for that switch? i ordered one today, it was ONLY $10 I'm wireing up my fog light on it.
    I asked the parts guy and got a stupid look, then i asked the srevice guy and hot thretened...(waranty)
    Dealers are totaly worthless, WORTHLESS i say!, Oh did i mention that im a parts guy at a dealership my self
    Life Dosn't come with a reset button, if it did you might as well turn the game off.
  2. #82
    Feb 2006
    mississauga, On.
    sorry to be bombarding your thread, check out "2001 Mitsubishi Spyder GTPC" in the show off your ride section, he did what you should do, he got his crappy HU and glued all the buttons on to it and used it like a faceplate on his screen...
  3. #83
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    i don't know what the fog light switch is like, but the VSA switch i used is as follows:
    Pins 1-2 are contacts for the momentary switch
    Pin 3 is not used
    Pins 4-5 are power for the switch illumination. I don't seem to remember these being polarized. In any case, i think the illumination + is red/silver and illumination - is gray/silver in the civic. Experiment with those.
  4. #84
    Feb 2006
    mississauga, On.
    yah, the dingbats at honda told me that the fog light switch costs $900, well you get the switch with the lights and the harnesses, well i can get oem lights from ebay for $100 and it comes with the harness. so I plan to use this switch with a variety of relays to run my custome fog lights...
    Ever see the new volvo trucks?, well they have prijection lights on the fron and i tore a few apart fom crash jobs and took the projection part out ^_^, So free is better then having to pay right?
  5. #85
    Jun 2007
    Oxnard, CA
    w00t!
    Hey thanks a lot for the wiring diagram ^_^
    --Tim
  6. #86
    Feb 2006
    mississauga, On.
    its me again, umm can you please tell me why you put those diodes in a loop like that on pins 4 and 5?, i dont see why it there?
    they are just for the light so dont they get direct power?
    thanks for the reply... and i cant figure out what the damm 3rd pin is for?, it has no resistance across and other terminal and no continuity, why would there be a dead pin?
  7. #87
    May 2004
    Denver
    dude, I am just now seeing this... this is total crap dude, I can't stand a friggin thief... I feel your pain... once I got my entire system jacked while I was at church!!! and another time I came back to my Porsche and the ignition was jacked, cause someone tried to start it with a screwdriver...
    I think getting out of those apartments is a good idea, time for you to house shop... DEFINITELY get a garage...
    hopefully by now things are looking up for you, we all go through runs of low... it helps us keep perspective on when life is good, you'll be in our prayers for the bits of sunshine that you are due...
    EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
  8. #88
    Jun 2006
    Denver, CO
    There's a good chance i was drunk when i made that diagram. I've updated it. I tested it with my multimeter and it doesn't show up as a diode normally would, so it's either just a regular bulb or there's some sort of rectifier built in... i have no idea. I just know it works and it's about 35 ohms across those two terminals... may very well be a bulb.
    The 3rd pin may be used in other applications, just not this one... sometimes it's just cheaper to leave it in than try and take it out when you don't need it.
    Quote Originally Posted by portabuddy View Post
    also -thanks matt-> i've put a deposit down on a house with a 2 car garage... so hopefully i'll be able to get financing for it. I'll keep everyone posted.
  9. #89
    Newbie boondocksaint's Avatar
    May 2007
    Detroit Metro Area
    Quote Originally Posted by GoHybrid View Post
    Nice. Garages rule. I'll never buy a house without one. I wish I live in CO. Alabama sucked. Moved to Michigan, and it sucks, too.
    What's the status on the repairs? <i>When</i> do you start the project again?
  10. #90
    Jun 2006
    Denver, CO
    rumor has it the car is ready to roll first thing tomorrow. we'll see!
  1. Replies: 6
    Last Post: 03-18-2007, 10:51 AM
  2. Custom Dash with 700TSV for 02+ Honda Civic Si
    By xmadcowx in forum Classified Archive
    Last Post: 09-06-2005, 10:12 PM
  3. 1999 Honda Civic SI HondaPuter
    By Chris732 in forum Show off your project
    Last Post: 08-11-2005, 10:37 PM
  4. 2001 Honda Civic Sedan Carputer.
    By dannn in forum Show off your project
    Last Post: 08-10-2005, 06:17 PM
  5. 99 Honda Civic Sedan Screen Install
    By CustomZ02 in forum Fabrication
    Last Post: 10-07-2004, 09:13 PM
