For the trunk panels, I used 1/4" Birch (as it's impossible to find 1/4" MDF now a days). They will be coated in fiberglass (for strength and to resist warpage) and finished in the same material as the trunk itself.
The carputer is going in the Driverside cubby
The amp for the speakers will go in the pass side
Each will have 2 lighted 80mm Case fans attached to the plexiglass cutouts. The lower fan will blow in and the upper fan will suck out.
I'm also incorporationg various LED light strips, wih all of it beign turned on/off by the opening closing of the trunk.
Since the areas in the trunk weren't large as I'd like. I'm going to have to hide an amp somewere else in the trunk (thinking about making a "pod" and placing it on the trunk lid.........,but would kill the factory look). I'm going to use the panel for the sub amp and hide a 4 channel amp for the high/mids.
Going to start on the Subwoofer fab soone enough. I'm placing a Kicker 10" DVC on either side panel next to the back seatx. I'm going to 'glass them in to use all available space. Will be hidden behind the panel so I won't have to do any outrageuos amounts of sanding as I did for the sub system in my GT
That took about 20 hours to complete. I figure I can do both sides of the GTO in under 10.![]()
LinkBack URL
About LinkBacks
