Here is a photo from my initial (indoor) setup and testing area:
I should mention that I have plenty of experience building computers, but not usually for a mobile application like this.
I used the cheap power supply and directly connected it to the MB and HD using the connectors first. I used a standard IDE cable and installed a HD and DVD Rom for the initial setup. Once I installed Windows I connected the M2-ATX to the MB and HD/DVD drives. I used a method I found on this site (I forgot the thread) in which you cut all the Yellow Wires and Black wires off the PSU. This gives you a 12V and a GND line simulating a car battery hookup. You then GND pin 14 on the PSU's Mobo connector so it thinks it is connected and will turn on, and I wired one strand of the yellow wires to a switch, which acted as a simulated ignition line. Overall it worked pretty well (photo below):
I also wanted my Lilliput to be powered from the M2, since at full power it pulls about an amp (12 watts or so). I decided to cut the end off the Cig lighter adapter that comes with the lilliput, and directly wired the + and - terminals to the 4pin addtl power adapter that fits on the M2. This, combined with the setting in the lilliput to auto-turn on with power, allows very low power consumption. The screen goes into 'sleep' mode when the computer goes to hibernate, and the M2 kills all power at Hardoff. Very slick stuff.
Since I also wanted a power button in the car, I took an old phone cable and used two of the wires and connected them to the J9 (I think) on the M2, so that it runs in parallel with the M2's Mobo power switch. This allows me to hibernate the system at any time, boot at any time (that the M2 is not hard-off), and also do a hard power off of the motherboard by holding down the button. The wire will be wired to the front of the drivers seating area so I can have easy access to it (and I already have a mute switch installed there for my pioneer deck).
Once the system is up and running, it was time to start looking at car install.
LinkBack URL
About LinkBacks
