Results 21 to 30 of 38
Thread: 04 Pontiac Vibe second run!
  1. #21
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    Hey boomin , looking good so far , can I ask you where you got that sticker on your windshield?
  2. #22
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    Quote Originally Posted by MatrixPC View Post
    Your install won't finish without blood.
    LOL true That might be the reason my last install never got finished
    Man, you really hack that glove box out.
    Yea I was just rough cutting to get it where it needed to be I have it mapped out so I can smoth the lines out and get them straighter and a little nicer.
    Quote Originally Posted by kevinlekiller View Post
    Hey thanks, I got the sticker from one of the guys at the first meet I went to in chicago, Any place that makes vinyl stickers could make one for you.
    Aron
    Absolutely 100% stock
  3. #23
    Apr 2005
    2hr west of Chicago
    Update April 11th
    I got a little further on the bezel so I thought I would post a couple more pics
    I like to tape off the areas That I dont want to get filler in because I like to apply it gererously so I only have to apply it once and sand down the rest.
    Filler applied and tape removed.
    All filler sanded down.
    I forgot to take a couple pics but I did spray primer on to get a better visual of the pinholes that body filler leaves. and then I put on a layer of glazing putty
    Buying update!
    My Iguidance 3.0 (legal version) and BU-353 came today
    Yesterday I picked up a linksys HGA7S wifi antenna this will be mounted on the a-piller.
    I also got a SMA 7ft extension cable so I dont have to use the base for the antenna.
    Power supplies will be here tomorrow
    Aron
  4. #24
    Apr 2005
    2hr west of Chicago
    April 12th Update
    My M2-ATX's came today so now I have everything except the keyboard that I will be running.
    Now it is time to install so pics should be coming
    Aron
  5. #25
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Where ya sticking the Hazard and defog buttons? Looks good so far!
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  6. #26
    Apr 2005
    2hr west of Chicago
    Quote Originally Posted by PontiacGA View Post
    Thanks. I'm going to put the cdrom, my processor controller, 4 port usb hub, as well as the hazard and defrost buttons into the lower armrest.
    Aron
  7. #27
    Apr 2005
    2hr west of Chicago
    Aron
  8. #28
    Apr 2005
    2hr west of Chicago
    Well I got it all in and running today but ran into a few snags.
    1. had trouble with the screen mounting because wires come out the rear.
    O.K notch the rear cover to allow clearence!!
    2. wasnt paying attention andkilled the harness fot the touch controler.
    Need to find a place to buy one if I can.
    3. body filler keeps breaking away from the monitor
    Im going to try to build it up some
    4. Had to drill a hole through plexi to run the mb switch and a ground up and cracked the plexi.
    The least of my worries but will fix when everything is working right.
    Will try post pics tomorrow
    Aron
  9. #29
    Apr 2005
    2hr west of Chicago
    I figured out why the monitor keeps cracking on me!!! there is moisture under the filler, so i guess I need to sand it down and start over. well here are some pics of the system up and running. I am still waiting on the extension cable for my wifi antenna so there are no pics of that yet.
    Here is a pic of the Glovebox shut
    Here is a pic of the P.C in the box You can see where it broke infront of the atx plug.
    Here is another pic of the P.C. from the driver seat
    Ashot of the monitor
    and for anyone that was wondering what my audio looks like, It is still under construction also but here are a couple pics
    I just got the Elemental Designs SQ10 and this thing is awesome in just .5 ft3 and of course my Zapco 500.1 and 360.4 amps. I also have some gray vinyl that I picked up a month ago just havent had time to put it on.
    Also My DSP-6 processor, I need to move it over to center it and also build an enclosure for it but there is a cover for it so that can wait
    Aron
  10. #30
    Constant Bitrate Felix509's Avatar
    Feb 2007
    Lafayette, LA
    Zapco DSP-6, Very nice...... That is what i will be getting if i cannot get all of the software Xovers, EQ, and delays working properly in my rig..
    Love Some ZAPCO
    Ours is the age that is proud of machines that think and suspicious of men who try to.
    ___________________________________
    Current SYSTEM
    AMD64X2 2.5
    Xenarc
    ZAPCO DSP-6
    ARCAUDIO SE Amps
    Rainbow Profi CS365 & Profi Vanadium 12"
  1. 2003 Pontiac Vibe GT All Done
    By pasic in forum Show off your project
    Last Post: 03-21-2007, 09:21 PM
  2. How to program factory installed xm radio in my 2004 pontiac vibe
    By giantg in forum General MP3Car Discussion
    Last Post: 02-02-2007, 01:10 PM
  3. Pontiac (Based on Orange Heat)
    By Jahntassa in forum CF Skins
    Last Post: 07-21-2005, 02:12 PM
  4. Replies: 11
    Last Post: 12-06-2003, 04:23 PM
  5. Those who run fans for cooling??
    By osirisdon in forum General Hardware Discussion
    Last Post: 06-12-2003, 09:30 AM
