Results 1 to 4 of 4
Thread: xenarc monitor vs the others
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    I currently a xenarc 7" tsv monitor from 2006 which will be dead soon. I was thinking about getting a new one soon, wounder which one to get. been looking at the 10.2 tsv one also, which is better. 10.2tsv or the 7" tsv? also what about xenarc monitors vs others?
    Newbie xenarctech's Avatar
    Aug 2009
    Quote Originally Posted by customaudioman View Post
    It all comes down to which size would fit your install better. We also have several different 7" models now. So you can pick one depending on your budget and your requirement. If you have question, you can call and talk to one of our customer service representatives.
    A lot of companies out there use recycled LCD panels so you should becareful. We use brand new, A-Grade panels at Xenarc. And if you get a bad pixel within 30 days and it bothers you, you can always send it back to us for exchange. Our LCD panels are also in general brighter because we upgrade our backlights. We also use better components (such as solid capacitors or Chip Monolithic Ceramic Capacitors) and offer 18 months warranty which is longer than others out there. There is also a difference in Touchscreen panel. Most of our models use 5-Wire Resistive touchscreen panel which is more responsive, has better optical clarity, and last much longer compare to 4-Wire Resistive touchscreen.
    Oct 2005
    thanks, will check them out. Do you guys sell the 10.2 tsv monitor raw w/o the frame?
    Aug 2009
    We do but only in quantity.
  1. Hardware Review: 2010 Xenarc 700TSV TFT LCD Touch Screen Monitor
    By Sonicxtacy02 in forum Mp3Car Blog Talk
    Last Post: 01-27-2010, 05:30 PM
  2. Poor audio quality Xenarc MDT-X7000?
    By jconfidence in forum General Hardware Discussion
    Last Post: 08-11-2008, 12:53 AM
  3. Pandora w/ Xenarc 700TSV and Barrel Connector
    By froalskiner in forum General Hardware Discussion
    Last Post: 07-20-2006, 03:39 AM
  4. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  5. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
