No you cannot drill holes in the LCD panel. The monitor has foam inserts between the LCD panel and the main board mounting plate. The main board mounts to a plate and is attached to the monitor in three places. There are also 2 speaker connections and one 12 pin connector that goes to the button board on the front bezel.
The monitor works without the speakers or the button board attached. You will not have any control of the monitor functions however.
LinkBack URL
About LinkBacks
