Results 1 to 7 of 7
Thread: 805TSV IR Wiring
    Constant Bitrate cazzz's Avatar
    May 2012
    Florida
    805TSV IR Wiring
    I have installed the 805TSV in my car.
    The next step is to install an IR sensor and wire it to the monitor.
    I would like to avoid installing the entire bezel.
    Any ideas on the wiring diagram for the button board on the bezel.
    I need to know which wires need to connect to the IR sensor.
    May 2012
    Florida
    I was able to determine that the IR sensor is wired as follows:
    Terminal A - wire 11 should be the output
    Terminal B- wire 1 (red) should be ground
    Terminal C - wire 10 should be 3-5v
    However, i found a couple different terminal configurations.
    I do not know what frequency IR sensor to use. There seems to be 2 common freqs, 38.5Khz and 56.8Khz.
    May 2012
    Florida
    I plan on testing the LCD remote as follows. I have a 38.5Khz IR sensor, hopefully this will work.
    Then I have to figure out which wire goes where.
    Here we will connect the detector as such:
    Pin 1 is the output so we wire this to a visible LED and resistor
    Pin 2 is ground
    Pin 3 is VCC, connect to 5V
    When the detector sees IR signal, it will pull the output low, turning on the LED - since the LED is red its much easier for us to see than IR!
    May 2012
    Florida
    Success!!!!
    Using the Xenarc remote I was able to receive the signal using the 38.5Khz IR sensor.
    The next step is to wire the sensor directly to the LCD panel and get the remote to work.
    May 2012
    Florida
    Setback!
    I connected the appropriate wires from the LCD main board to the IR sensor on the bezel button board.
    Remote did not work with only 3 of 12 wires connected.
    I also could not see any voltage on the sensor.
    I tried hooking up my powered IR sensor to the output line going to the LCD but that didn't work either.
    It would be real nice if Xenarc would help out......what will it take to get the remote to work without using the entire bezel?
    In the mean time, I will rewire the entire harness and see if the bezel is working.
    May 2012
    Florida
    Just got an email from Xenarc.
    Waiting for some details.
    Great support and they were quick to respond.
    PM me if you ever need contact info.
    May 2012
    Florida
    Thanks to Jimmy Hu at Xenarc. The support has been fantastic.
    My IR circuit has been wired to the LCD panel and the remote works.
  1. Xenarc 805TSV Installation
    By cazzz in forum Xenarc Monitors Forum
    Last Post: 07-15-2012, 08:51 AM
  2. powering the xenarc 805tsv with regulated 12vdc?
    By jake5253 in forum LCD/Display
    Last Post: 09-30-2011, 09:59 PM
  3. Help wiring into stock amp wiring harness
    By armysgt in forum Car Audio
    Last Post: 06-11-2009, 04:13 PM
  4. Power Wiring Issue & General Wiring Question
    By speed_krazy in forum Newbie
    Last Post: 05-19-2006, 02:17 PM
